Masterworks Gate has no linked controls for stereo? I forget this over and over....
....and don't understand it. It's seriously unwieldy. 12 knobs to set individually on a stereo source rather than a linked 6 pair!
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
- FMiguelez
Re: Masterworks Gate has no linked controls for stereo? I forget this over and over....
There's a way to join stereo parameters... I think you must press Option (or is it control?) as you adjust them, and some parameters will be linked on both sides.
Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
DP 10.13, OS 13.6.7, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
Thanks again gents. Of course, this is good info, but a Stereo Link button on the plugin would be awfully nice, too.
That does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
All I did was follow the Digital Performer Plug-ins Guide. These are screenshots from there, and it works just as written (but I'm still on DP10.13...not sure if anything has changed since then).EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
When I hold them BOTH down at the same time, it does what I'd expect; Stereo control with fine-tune adjustments.
I hope that made sense.
Ditto The manual says the option key works, but here, no key combo works.EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Tritonemusic wrote: ↑Fri Apr 14, 2023 11:02 amAll I did was follow the Digital Performer Plug-ins Guide. These are screenshots from there, and it works just as written (but I'm still on DP10.13...not sure if anything has changed since then).EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Thanks.....just doesn't work here. Didn't in DP8 either.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
Well, that is weird, guys. I tested it before posting, and tested it again. It still works for me. I wish I could help you figure this out.
Here's a question:
Does holding down Command while changing parameters on any stock DP plug-in make a difference, as far as fine-tuning is concerned?
Here's a question:
yes, Command works for fine turning.
Yes, command has always worked for me. I use that all the time.Tritonemusic wrote: ↑Fri Apr 14, 2023 2:07 pm Well, that is weird, guys. I tested it before posting, and tested it again. It still works for me. I wish I could help you figure this out.
Here's a question:
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
- pencilina
I noticed option (to link channels) not working a year or s ago) to motu tech support, they confirmed and like lots of other confirmed bugs its still broken......
Thanks for the the info, pencilina. I guess that explains why mine's still working (DP 10.13).
