Thunderbolt 2 on 2019 Mac Pro?
- npatton
Trying to find the latest info on this topic. Was just given (!) a 2019 Mac Pro, but my MOTU 828x and hard drives are Thunderbolt 2, so no ports.
1. I have HEARD that TB 2-3 adapters can be sketchy or erratic. Still true?
2. Is there a reliable card I can install in the MP that would provide Thunderbolt 2 connectivity?
Trying to avoid forking out for another interface if I can help it. Grateful for any help or links.
Thanks,
n
Thanks,
n
Mac Pro (Late 2013) (3.5 GHz 6-Core Intel Xeon E5, 32 GB RAM) OS 10.13.6
MacBook Pro (2 GHz Intel Core i7, 8 gigs RAM); OSX10.11.6; DP 10.13; Unisyn 2.1.1; Stylus RMX; MOTU MIDI Express XT; MOTU 828x; Kurzweil PC3 with Kore 64; Roland XV-5050, D-50; Alesis QS7; Yamaha S90ES, TX-216; Hammond XK-3
FWIW, my own music can be heard at...
http://www.neilpatton.net
http://http://www.pandora.com/neil-patton
Business Site: http://www.pattonmusic.com
Re: Thunderbolt 2 on 2019 Mac Pro?
Get the Apple Thunderbolt Adaptor... it works fine, at least for me using a Mac Studio with TB1 MOTU 828ES Audio Interface.
Nice to be given a 2019 Mac Pro. Congrats!
HC Markus
What he said. The Apple adapter is rock solid. It plugs into the TB3 or TB4 (depending on the Mac).
https://smile.amazon.com/gp/product/B01 ... asin_title
There are many cables with that plug that are not Thunderbolt (read the extra fine print: so-called Thunderbolt video is really MDP). You need a TB2 cable—any of these will do:
https://smile.amazon.com/Certified-Cabl ... r_1_1_sspa
One nice thing about using an interface that uses TB1 or TB2 is you can get a 3-Meter cable for a reasonable price, as linked by MIke, although the necessity of the Apple Adaptor cuts the cost savings compared to the new $160, 3-Meter Apple TB4 Cable.
- npatton
Thanks so very much, everyone. Very helpful, and also encouraging. I know I could always use the USB 2 ports, but having the faster and larger throughput is what I want. I will try the adapter.
I also have a set of ss hardrives (OWC Thunderbay) that I have used via TB, so hoping I can continue to use that via adapter, as well.
Thanks again for your time!![Smile :)](./images/smilies/icon_smile.gif)
Maybe. OWC has used Thunderbay to cover many different drives over the years.npatton wrote: ↑Wed May 25, 2022 8:45 am Thanks so very much, everyone. Very helpful, and also encouraging. I know I could always use the USB 2 ports, but having the faster and larger throughput is what I want. I will try the adapter.
Thanks again for your time!![]()
If it has two TB ports, you should be able to daisy-chain them with TB2 cables. Since the 828x has only one TB port, it goes to the end of the chain. The spec allows up to six in a chain.
I have an old OWC TB2 dock with a pair of SSDs in between my 828mkII and my iMac Pro.
- npatton
Thanks! Should be OK. I will have the Thunderbay on a separate TB port, so no daisy chaining will be needed. The computer has four TB 3 ports, and I will only be using two for now (828x and Thunderbay). I've ordered two adapters. I will run my video monitors from the two HDMI ports, as well.
Thanks again!
n
Thanks again!
n
