MOTU MIDI TimePiece AV USB and macOS Monterey
Hi everyone,
I have been using a MOTU MIDI TimePiece AV USB (firmware chip v. 2.01 and rom chip v. 1.32) standalone for a while now and I love it. However, I just bought a new 2021 macbook pro with the m1 pro chip (that comes preinstalled with macos monterey) for my studio and I was wondering if I would be able to connect the MOTU to my computer via the USB port. Is it class compliant or are there drivers or software anywhere that I need to download? I know it is an old unit but I hope I can get it working somehow!
Thanks so much!
Thanks so much!
Re: MOTU MIDI TimePiece AV USB and macOS Monterey
Hi,
Long story short, MOTU no longer supports their older hardware. In this case, the drivers for the current MIDI devices work with the older ones, too — you just have to know which units use the same driver and where to look. Go to this site and find MIDI Interfaces in the left drop-down; MIDI Express XT on the right. You'll see a driver for MacOS 12 and a manual that also covers the MTP USB AV.
https://motu.com/en-us/download/
Here's a direct link to the manual foe Mac
https://cdn-data.motu.com/manuals/MIDI/ ... de_Mac.pdf
Inside, there's a CR2032 settings battery. Unless you know it's fresh, change it. 2 screws holds the top on, slide the cover toward the back to remove IIRC. Besides not holding settings, a battery that's too old can leak and cause damage to the insides—no one wants that. Hmmm... wonder how long it's been since I've changed mine?
While the cover is off, look at the sticker at the EPROMs—if one doesn't show 1.32, this will not work with an Intel Mac (or an M1 either, I presume).
![Image](https://a1-images.myspacecdn.com/images04/3/569fa0f534b0437ea7f407d5f8523799/300x300.jpg)
Likewise, the Firmware must be 2.0.1. This is displayed on start up also.
https://a3-images.myspacecdn.com/images ... 00x300.jpg
These have been unavailable from MOTU since 2012 when I bought the last pair. If yours don't match, I've seen replacements on eBay and Reverb in the last couple years.
- shansen1
My MIDI Timepiece AV USB, Firmware 2.01, worked perfect in OS 12.3 on my Mac Pro Late 2013.
But with my new Mac Studio Max, it does not work.
I talked to Motu tech suport and they told me that it will not work on this new processors.
All the MIDI interfaces from Motu has som years since they was produced.
Anyone have some suggestions for a new MIDI interface? I do not need so many in and out anymore som 4 in and 4 out should be enough.
Well that seems like the definitive word. Time to dump my MTP/AV and get myself a new *supported* MOTU MIDI interface.shansen1 wrote: ↑Fri Mar 25, 2022 9:15 am My MIDI Timepiece AV USB, Firmware 2.01, worked perfect in OS 12.3 on my Mac Pro Late 2013.
I’m in the same boat, once I move to AS M1. Not there yet but soon-
Greg.
Greg.
One thing to consider is that there's probably a current MOTU MIDI interface that will work with Intel Macs AND will be able to make the transition to M1 Macs. Might be smart to buy one of those now and offload old MTP/AVs for whatever you can get for them. Before long, when word gets out, you won't be able to give them away.
Did you actually try downloading and installing the newer driver. It's not obvious that it works for the MTP/AV but there's another user on this board that has it working with an M1 MacBook Air:shansen1 wrote: ↑Fri Mar 25, 2022 9:15 am My MIDI Timepiece AV USB, Firmware 2.01, worked perfect in OS 12.3 on my Mac Pro Late 2013.
Michael Canavan wrote: ↑Sat Mar 26, 2022 4:27 pm James, I'm using an MTP/AV on the M1 with the MacBook Air.
I guess I didn't explain it well, but basically MOTU are behind on their website when it comes to the MTP/AV. When you go to download the driver it only shows the one from 2017 which won't work. BUT!! if you select the Express XT or 128 you get the latest driver. Download it and during installation it will ask you what interface you're installing it for, and the MTP/AV is one of the choices!![]()
Looking at the MOTU website, examining all the MIDI interfaces offered, (I think there’s only four), I see no mention of support for the new Apple Silicon machines. So I don’t know if MOTU has officially announced that their MIDI hardware is AS-ready. I’ll be looking here for anecdotes from you guys/gals!
greg328 read Jame's post directly before yours. Yes MOTU's MIDI interfaces including the MTP/AV are working natively on M1 Macs, but they dropped the ball with updating the MTP/AV page to show that, downed the driver "for" the Express or 128 and it will prompt you if you are using it for the MTP/AV or not when you install it. Clockworks is M1 native as well.greg328 wrote: ↑Sat Mar 26, 2022 5:07 pm Looking at the MOTU website, examining all the MIDI interfaces offered, (I think there’s only four), I see no mention of support for the new Apple Silicon machines. So I don’t know if MOTU has officially announced that their MIDI hardware is AS-ready. I’ll be looking here for anecdotes from you guys/gals!
This feels like such a gift not to have to replace my MIDI interfaces if I get a new M1 Mac at some point. Awesome that Clockworks is M1 native and can, I assume, manipulate the settings of the MTP/AV.Michael Canavan wrote:greg328 read Jame's post directly before yours. Yes MOTU's MIDI interfaces including the MTP/AV are working natively on M1 Macs, but they dropped the ball with updating the MTP/AV page to show that, downed the driver "for" the Express or 128 and it will prompt you if you are using it for the MTP/AV or not when you install it. Clockworks is M1 native as well.greg328 wrote: ↑Sat Mar 26, 2022 5:07 pm Looking at the MOTU website, examining all the MIDI interfaces offered, (I think there’s only four), I see no mention of support for the new Apple Silicon machines. So I don’t know if MOTU has officially announced that their MIDI hardware is AS-ready. I’ll be looking here for anecdotes from you guys/gals!
- shansen1
I used the last driver all the time, with my old Mac Pro and in the new Mac Studio, the MTP AV has the last chip update and I even put a new battery.James Steele wrote: ↑Sat Mar 26, 2022 4:59 pmDid you actually try downloading and installing the newer driver. It's not obvious that it works for the MTP/AV but there's another user on this board that has it working with an M1 MacBook Air:shansen1 wrote: ↑Fri Mar 25, 2022 9:15 am My MIDI Timepiece AV USB, Firmware 2.01, worked perfect in OS 12.3 on my Mac Pro Late 2013.
The sad message is that the old MTP AV does not work in Mac studio. That is also confirmed by the Motu tech support.
Actually all the MIDI interfaces from Motu has som years on their back. And the info about the drivers is not crystal clear if they really work with the new macs.
I think you didn’t do what I’m telling you to do. I’m sorry if that seems rude but there’s absolutely no reason that the driver would work in my M1 Air but not work on your Mac Studio, none.shansen1 wrote: ↑Sun Mar 27, 2022 4:16 amI used the last driver all the time, with my old Mac Pro and in the new Mac Studio, the MTP AV has the last chip update and I even put a new battery.James Steele wrote: ↑Sat Mar 26, 2022 4:59 pmDid you actually try downloading and installing the newer driver. It's not obvious that it works for the MTP/AV but there's another user on this board that has it working with an M1 MacBook Air:shansen1 wrote: ↑Fri Mar 25, 2022 9:15 am My MIDI Timepiece AV USB, Firmware 2.01, worked perfect in OS 12.3 on my Mac Pro Late 2013.
Again if you instal the latest driver in the downloads section that MOTU directs you to when you select the M1 it will not work, select the driver for the express XT and it will.
I'm eagerly awaiting the outcome of this thread. I'm hoping to buy a Mac Studio in October or so... definitely before the end of the year so I can take the write-off. It would be a relief to know I can keep my old MIDI interfaces... especially since with the dominance of VIs today, I'd hate to have to spend more money just to keep my "nostalgia" synth modules connected. Although I don't use them frequently, every so often I may use them. Also, unless there are manufacturers who are going to make devices that conform to the MIDI 2.0 spec, can't see a need to update MIDI interfaces with the 5-pin DIN plugs.
Please try downloading this driver. It flatly states it's Monterey and MTP/AV comparable, you select the appropriate instal after download.shansen1 wrote: ↑Sun Mar 27, 2022 4:16 am I used the last driver all the time, with my old Mac Pro and in the new Mac Studio, the MTP AV has the last chip update and I even put a new battery.
https://motu.com/en-us/download/product ... s=true#108
- shansen1
Dear Michael,Michael Canavan wrote: ↑Sun Mar 27, 2022 12:04 pmPlease try downloading this driver. It flatly states it's Monterey and MTP/AV comparable, you select the appropriate instal after download.shansen1 wrote: ↑Sun Mar 27, 2022 4:16 am I used the last driver all the time, with my old Mac Pro and in the new Mac Studio, the MTP AV has the last chip update and I even put a new battery.
That is the driver I have been using all the time, and I am sorry to say it again. It does not work with Mac Studio machines.And so say the Motu tech support.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
