If you have used Digital Performer for any time, I think you know the answer to this. It does not have that same feature from Reaper. Reaper doesn’t have some features that Digital Performer has, either. I certainly don’t have time to go into a comparison of each DAW. I would say this though, that you should perhaps consider having some sort of safety limiter engaged when you mix down to catch the occasional overs.
James Steele wrote: ↑Sun Feb 13, 2022 8:20 am
OK thanks so you mean DP has some sort of safety limiter for this purpose . Can you kindly tell me how to add that?
Masterworks Limiter should be placed on the output Bus that feeds your mix track. Set max level to wherever you desire; -1.0dB is a good level that should avoid most, if not all, inter-sample overs.
You can also use the Limiter to tame peaks in your mix and thus bring the average level up a bit. Google "Audio Mastering".
