This is craaaazy!! So I am still hanging on to my Focusrite LiquidMix. Probably should phase it out since I have Softube Console 1 now. Anyway, it's 32 bit so I have to run Mojave to run 32Lives... but this is a kick! I recently bought a perpetual license for ProTools of Craiglist (which worked out fine... it was a gift seller received unopened). As a proof of concept I wanted to see if I could figure out a way to use LiquidMix in ProTools. That's a challenge. We're talking 32-bit AU for a DAW that only uses AAX. Well updating my Blue Cat Audio plugs, I came across this gem:
https://www.bluecataudio.com/Products/P ... PatchWork/
This thing is unbelievable. It's pricey I guess at $99.... I don't know if there's a bundle, but I installed the AAX version and this silly thing has LiquidMix WORKING in ProTools 2021.7! It seems like this very easily lets VST and AU effects (including those wrapped with 32 Lives) work in ProTools. I haven't done extensive testing... no VIs yet, but seems a lot simpler workaround than VEP and I doubt it will have the latency (assuming I get VIs working) that the VEP solution would introduce.
If you are a doubter...
![Smile :)](./images/smilies/icon_smile.gif)
... I've attached a screen grab of Liquid Mix running in ProTools. I went back and did the screen grab over while PT was playing so you could see level meters going on LiquidMix plug in... the meters on the hardware work fine too. Crazy
I moved this over to General Macintosh since it is not DP related, but for those of you that have PT also (I got mine mostly to transfer projects) thought I'd share this discovery!
![liquidmixinpt.jpg](./download/file.php?id=15&sid=35a4c4324057d07f2b0b5877df08815b)
- liquidmixinpt.jpg (212.58 KiB) Viewed 565 times
