Sending audio from DP to Vienna Ensemble Pro 7
Gone To Lunch
Post by Gone To Lunch »
I have figured out how to host my VIs in VEPro7, send them MIDI and receive audio back into my DP, but I am struggling with sending audio from DP to VEPro7.
The VSL instruction video says
“Using the audio outputs of Vienna Ensemble Pro, you can route an audio signal internally. For example to certain buses or back to your sequencer. Again, each sequencer is different in this regard and you will find more information in your Vienna Ensemble Pro manual.
You can also process audio signals from your sequencer. Insert an audio input plugin in the audio track of your sequencer and assign this plugin to the already established Vienna Ensemble Pro connection.”
In the context of MOTU DP, an audio input plugin is presumably an aux bus or an audio track, as they are the only audio carriers? But there is no explanation in the manual of how to connect them to send audio from DP to VEPro7, only about how to connect instruments and receive their audio into DP.
Obviously the VEPro7 module that sits in DP must support 2-way traffic, but I can’t figure out how?
http://gonetolunchmusic.com/
Current sex toys : DP 11.32, Mac M1 Studio OS 13.6.3 64 gb Motu M4. Sounds by VSL, Addictive Drums 2, Native Instruments, Orange Tree, Bolder Sounds. Plug-ins by PSP, VSL MIR Pro 3D, 2CAudio, Waves & Lexicon. Scores by Dorico Pro 5.4.
Gone To Lunch
Re: Sending audio from DP to Vienna Ensemble Pro 7
Problem solved - VSL tech support explained it thus:
I asked:
In the context of MOTU DP, an audio input plugin is presumably an aux track or an audio track, as they are the only audio carriers?
They replied:
Yes, simply insert a VE Pro Audio Input MAS plug-in into an aux track in DP and assign it to an already connected VE Pro instance, then create an Input channel in the VE Pro instance with the corresponding inputs.
