I had Unisyn working fine on an old Mac running in Classic mode. Then the computer broke down irreparably . I obtained another computer, installed Classic, installed Unisyn 2.11 - but it's asking for the key code. ("can be found on the inside back cover of the Read This First guide", which I no longer have ) I got a code from MOTU tech support, but doesn't work and they haven't responded to my request for options, I know they don't support this any longer.
I have an older version of Unisyn with a key code (they were printed on the CD then) but my files won't open in the older version.
I have one old synth that can only be run with Unisyn... I'd be grateful for codes to try, or other suggestions.
Key Code needed
Re: Key Code needed
The question would be why a Key Code given you by MOTU Support wouldn't work.
If there are dashes and you are using minus signs, that's one reason. That used to trip me up all the time.
How about Hidden Auth files? If so, those need to be found and deleted, then Permissions need to be rebuilt if you are on OS X.
https://motu.com/techsupport/technotes/ ... hterm=auth
Finally, what's your hardware? Classic Mode isn't supported on the G5 (OS 9.04 could not be installed on these). A G4, OTOH, can run OS 9.04 – 9.2.2, still available on Macintosh Garden.
https://apple.fandom.com/wiki/Classic_(environment)
Mirror site for Macintosh Garden
https://archive.org/details/Macintosh_Garden_Collection
