I was on the VSL page, and I saw a lot of products... maybe too much
![Very Happy :D](./images/smilies/icon_biggrin.gif)
I simple need a VEP container where put all my AU virtual instrument. I don't need the orchestral sound. What do I've to buy???
Thanks everybody
Definitely, for Tlaloc's sake!bayswater wrote:Does VEP do anything useful if you don't use their instruments and only run on one computer?
FMiguelez wrote:
...you host every VI you have (and possibly plugins, using VEP7 as an effects "send") from this single great environment...
FMiguelez wrote: ...you control from DP's chunks...
FMiguelez wrote: It takes control over everything about CPU for you. Sending audio, MIDI CCs, anything, is just great. All your VIs live in the server that belongs for the specific project. ALL your settings for all VIs are then saved as part of the Server Project, and/or as part of a DP V-Rack chunk itself, so all that info is safely stored in there.
What I call a coffee break... lolFMiguelez wrote: You can have your FULL template enchilada Server project always opened and ready, and you can selectively choose what is loaded or unloaded at any given time, so RAM management becomes almost a non-issue.
I always start from scratch on every project. No preconceived notions on how my creativity is being utilized.FMiguelez wrote: You can also change chunks and projects as you wish, and you don't have to reload anything, since it can stay opened and fully loaded, which is specially great if you work from a template.
I don't even have a response for that. I can do everything in my little old Mac Pro trash can. "FMiguelez wrote: If you have an old computer laying around, and it still can run VEP7, you can easily incorporate it as a slave-Software-rack into your workflow, and ease some of your main computer's CPU power this way. This is how I survive, with a Mac Mini (and iMac) farm of currently 5 computers.
Simplicity is the ultimate sophistication." da Vinci
I don't find looking as important as playing and listening, but that's just me.FMiguelez wrote:The GUI is awesome. It's a pleasure to even look at it, since it invites (at least for me) you to compose...
How'd I ever making a living composing over the last 50 years without it?FMiguelez wrote:I think it's free to try out. Check it out, Bays. If you use LOTS of VIs and MIDI programming for your music, I just don't understand how anyone could live without it. It's that good.
mikehalloran wrote: Speaking of that i9, it has 10G Ethernet, right? If yes, forget Master/Slave. You can link additional Macs through the T2 chip and a Cat6/6a/7 cable to combine horsepower as long as those Macs have 10GBe. According to Apple, 1G Ethernet Minis can't do this.
No. I mean using VEP without going Master/Slave but it can also mean simply hosting your VIs in a more robust environment.labman wrote:mikehalloran wrote: Speaking of that i9, it has 10G Ethernet, right? If yes, forget Master/Slave. You can link additional Macs through the T2 chip and a Cat6/6a/7 cable to combine horsepower as long as those Macs have 10GBe. According to Apple, 1G Ethernet Minis can't do this.
Mike, so you mean a direct 10G connection without using VEP?
So there are a few reasons to use VEP. The main one is for servers, using more than one computer with a Slave machine wired over ethernet.magnas wrote:Hello everybody, after several attemps with my new MacBook Pro i9 with 32 GB of RAM, I think that the best way for optimize the project and the RAM/CPU usage is using VEP in my project (a lot of user gave me this advice from years).
I was on the VSL page, and I saw a lot of products... maybe too much![]()
Thanks everybody
No. I mean using VEP without going Master/Slave but it can also mean simply hosting your VIs in a more robust environment.mikehalloran wrote:
This looks promising, but I've never heard anyone talk about doing this with real time audio streaming. There's a huge difference between rendering movie and animation files and what we do. I would love to be proven wrong, but I can't think of a single person that's hooked up two computers using the latest ethernet protocols and had extra horsepower in their set up.mikehalloran wrote:As for the Master/Slave arrangement, if you need to go there, you'll know. Might not be necessary with an i9 MBP and 2TB storage under the hood.
At the 2018 WWDC, Apple was demonstrating stacks of 5, 10 & 20 linked Minis working on single AV files. Since the MacPro 7.1, they don't talk about this anymore.
