DP 10, MXL Tempo usb... Error meaning??
arsis
Post by arsis »
Catalina, DP 10, MXL Tempo usb mic. I get this error message.
"Digital Performer cannot use this CoreAudio driver as it is currently configured because no outputs are available. You must configue the driver so that the MOTU Audio system can use at least one output pair."
The headphone output works but it will not show up as an input. How do I fix it?
Lenovo Yoga i7, 16RAM, DP 10.11, Waves analog modeled plug-ins, AmpliTube, Shreddage 3 Jupiter, Mackie HR824 Mk1, Tobii Eye gaze mini.
Yes, I do everything using only my eyes. #ALSsucks
Even when I'm new school I'm old school.
Re: DP 10, MXL Tempo usb... Error meaning??
Your sig says windows but you posted in the Mac section. Which is it?
arsis
Post by arsis »
MIDI Life Crisis wrote:Your sig says windows but you posted in the Mac section. Which is it?
My main system is a PC but I'm setting up the MXL Tempo mic on a Macbook.
The first thing I'd do is check for a driver updates.
It is showing up correctly the Apple AUDIO/MIDI setup app?
arsis
Post by arsis »
MIDI Life Crisis wrote:It is showing up correctly the Apple AUDIO/MIDI setup app?
yes. It shows record level in system settings.
CharlzS
Post by CharlzS »
Create an aggregate device in Audio MIDI Setup that has the USB mic plus whatever output(s) you want to use selected and pick that in DP hardware setup. That aggregate device will be available to all apps. Also, one other option should be to select multiple devices in DP hardware setup by cmd-clicking them (or is it ctrl-clicking - not at a Mac right now). Pick the outputs and then cmd-click the USB mic.
If you ever need to do this on a PC, you can use ASIO4ALL to create the PC equivalent of an aggregate device. The second option, selecting multiple devices in DP, is not available on PC.
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
