So I thought it might be worthwhile to try and uncover what exactly it is that people might be doing (or not doing) which makes DP prone to crashing or seemingly immune from it?
It's not an easy question to answer - how do you use DP? - but it's still an interesting enough question to ponder because I suspect maybe some of things we do in DP are so habitual we don't fully realise they may be a major factor in making DP's operation either a
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
And also some of us might be better at spotting (conciously or not) patterns of behaviour when working with DP which lead to crashes, hangs, small fires etc and so learn to work a slightly different way to avoid them.
Here's one off the top of my head: although I don't get quits or hangs very often, one sure fire way for me would be to try and switch the instance of a CPU hungry VI by simply opening that VI's drop down menu and selecting the new instance. (Especially true if going from an AU to a VST (using audioease VST wrapper). DP will then usually close the current VI and just before the new one opens -QUIT!. So I always delete the VI first, then save, then open the new instance in its place- never a problem.....and it's a habit now, I don't even think about doing it another way.
So if you have definate 'no no' or a 'yes yes' or even a 'not sure if this is bad' ways of using DP then post them here ......
G5 dual 1.8
10.3.9
1 GB
DP 5 - OK I mean 4.61
