Windows - Expired certificate in installer
toddbooster
Re: Windows - Expired certificate in installer
Post by toddbooster »
I can't even that this is still a thing. It's been two months since I reported it initially. Expired certs are not cool.
Intel Core i7 8700K, 32 GB, Windows 10 Pro, DP 10.13, MOTU Ultralite AVB.
terrybritton
Post by terrybritton »
Although one can set their clock back to September and uninstall 10.01, I discovered that if you already installed 10.1 then uninstalling 10.01 breaks the "Welcome" screen in 10.1, throwing a script error and removing all the javascript links. The only solution is to uninstall 10.1 and re-install it, as using "Repair" in 10.1 does not fix this problem. I have reported it to MOTU tech support by phone this morning.
Also told them how the certificate issue prevented uninstalling 10.01, not only installing, and they were not aware of that and confirmed it.
So, two bugs added to their logs. We'll see if they update the certificate and place the resources the 10.1 "Welcome" screen uses somewhere different from where 10.01 puts them (and removes them).
Terry
MOTU 828 mk3 hybrid
thejfisher
Post by thejfisher »
At least that was a quick easy fix albeit annoying. Time change worked.
m2_linux
Post by m2_linux »
it is still an issue in Version 10.13 in 2023
m2_linux wrote: Sun Jun 11, 2023 2:42 am it is still an issue in Version 10.13 in 2023
What build of Windows?
