Any clue, my brilliant friends? This is with a template I use quite frequently.
DP has enountered an error.
Mas,1 error reported by Mas Audio Unit Support
Failure: Bass::New 160 - 50 (50)
Thanks in advance....!
Sudden error at startup
- cbergm7210
http://www.rfjmusic.com
Re: Sudden error at startup
A path may be corrupted. When this happens, I reinstall DP 8 or 9, shut down and do a Safe Boot by holding the Shift key. After logging in, shut down and Boot normally. See if you still have a problem.
Normally, you don't have to delete anything including preferences.
