Stereo to mono
Stereo to mono
Hi Guys,
I'm using a plugin on a VO that only works in stereo, so I have to record in stereo but there's no reason I need the final file to be in stereo. Is there a way, when exporting, to turn a stereo file into a mono one?
Mac mini M1, 14.3.1, 16gigs RAM, 828 mk3 Hybrid, DP 11.23, Various VIs
Re: Stereo to mono
Not sure about exporting, but you can convert it to mono via Bounce-To-Disk.
In the BTD window, you'll see an option where you choose Stereo or Mono. I would recommend selecting the mono option with 3.5 dB attenuation, otherwise it might clip.
DP 10.13, OS 13.6.7, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
Re: Stereo to mono
There's a sneaky way to do this:
1. Create an Aux track assigned to stereo bus (say bus 1-2) output, with it's input set to your source, and place your stereo plug on an insert slot.
2. Create a mono bus 1 OR 2. You'll have to manually drag the marker square in the bundles setup.
3. Create a master fader assigned to bus 1-2 and set fold down to mono.
4. Create a mono audio track with input set to either bus 1 or bus 2 (whichever you chose in step 2). This will be the track you record arm and will be a mono mix of bus 1-2.
[edit] Alternatively, if you've already recorded a stereo track, you could use the stereo track in place of the Aux track.
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Re: Stereo to mono
Ok thanks. As soon as I can figure out how to do the suggestions here I'll try them ![Wink ;-)](./images/smilies/icon_wink.gif)
Gavin
Gavin
Re: Stereo to mono
I also use ProTools and they offer mono aux,s, VI,s etc. I wish DP made it easier. When I create a VI bass track or solo violin, or solo VI, I do not need them in stereo. When I record an acc bass, I put 2 mics on it, and want to blend them together with a mono aux not a stereo.
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- rockitcity
Re: Stereo to mono
Tired of politics tonight so dredging up an old thread...apanacci wrote:I also use ProTools and they offer mono aux,s, VI,s etc. I wish DP made it easier. When I create a VI bass track or solo violin, or solo VI, I do not need them in stereo. When I record an acc bass, I put 2 mics on it, and want to blend them together with a mono aux not a stereo.
Simple solution to the double mic'd bass would be to record to two mono tracks linked. Easy to assign them both to a mono output. Or, just pan the stereo track center!
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
- Timeline
Re: Stereo to mono
Isn't that what we use trim? ...and for levels sets...
Re: Stereo to mono
Open the stereo file in the Waveform Editor > Command-drag to select one side of the waveform > choose Create Soundbite From Selection from the mini-menu. The new mono soundbite will appear in the Soundbites window - and also be in the Audio folder. No need to Export.
Re: Stereo to mono
That's worth repeating. Saved me some headaches just now. Thanks, Dix! Best solution in DP for this. Also for a lot of other stuff.dix wrote:Open the stereo file in the Waveform Editor > Command-drag to select one side of the waveform > choose Create Soundbite From Selection from the mini-menu. The new mono soundbite will appear in the Soundbites window - and also be in the Audio folder. No need to Export.
Re: Stereo to mono
It should be a sticky.MIDI Life Crisis wrote:That's worth repeating. Saved me some headaches just now. Thanks, Dix! Best solution in DP for this. Also for a lot of other stuff.dix wrote:Open the stereo file in the Waveform Editor > Command-drag to select one side of the waveform > choose Create Soundbite From Selection from the mini-menu. The new mono soundbite will appear in the Soundbites window - and also be in the Audio folder. No need to Export.
Re: Stereo to mono
Above my pay grade or it'd be done. What can i tell ya... lolmikehalloran wrote:It should be a sticky.MIDI Life Crisis wrote:That's worth repeating. Saved me some headaches just now. Thanks, Dix! Best solution in DP for this. Also for a lot of other stuff.dix wrote:Open the stereo file in the Waveform Editor > Command-drag to select one side of the waveform > choose Create Soundbite From Selection from the mini-menu. The new mono soundbite will appear in the Soundbites window - and also be in the Audio folder. No need to Export.
Re: Stereo to mono
I tried this yesterday but it didnt workdix wrote:Open the stereo file in the Waveform Editor > Command-drag to select one side of the waveform > choose Create Soundbite From Selection from the mini-menu. The new mono soundbite will appear in the Soundbites window - and also be in the Audio folder. No need to Export.
![Sad :(](./images/smilies/icon_sad.gif)
Any body know why?
Gavin
Re: Stereo to mono
Works here. I know if I’m not careful about the drop down selection I get undesirable results. I’d suspect that might be where the error is occurring.
Re: Stereo to mono
Actually, I recently noticed that the Command modifier is just an option that makes selecting one side or the other easier. You can simply drag if you place the curser at the top of the side of the waveform you want a mono file from. ...and then choose Make Soundbite From Selection from the mini menu. As noted above somewhere, this does strip off the timestamp unfortunately.
Re: Stereo to mono
Convert from Interleaved to Split Stereo in DP.
Drag to Desktop... two mono files. Take your pick.
