Come to think of it, I've been guilty of that.Shooshie wrote:I'd often get my edits done while the client was still listening to it.
DP 9.1 is here
Re: DP 9.1 is here
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
- bralston
Re: DP 9.1 is here
Anyone rush over and get the new VEPRo6 that was just released today and see if their slowdowns and glitches with a large template along with VEPro5 is improved at all?
I have one more cue to write here today and will probably chug through 9.1 to just get it done...spinning beach balls and all. But then before completely jumping ship back to 9.02...I may get VEPro 6 Upgrade and see what that does. At that point...why not? right?
Regards,
Brian Ralston
Brian Ralston
- bralston
Re: DP 9.1 is here
A report on the Digital performer Facebook group says that VEPro6 gave an error when opening in DP 9.1 stating to disable VST versions of the plug and use MAS instead...and, then on subsequent opening, could not open any VEPro6 instances in DP 9.1. I personally have not tried it yet as I am waiting for my download links from VSL...but I did purchase the update today. Regardless..tread lightly if anyone wants to test 9.1 with the new VEPro6.
Regards,
Brian Ralston
Brian Ralston
Re: DP 9.1 is here
Interesting. In 9.1 I couldn't BTD when PSP Xenon VST was present in the system (even if not in use). Crashed every time. Moved to the AU and no problems. So maybe there's an issue with some VSTs and 9.1?
- mhschmieder
Re: DP 9.1 is here
Oh, somehow I didn't notice it's already released -- I thought it was simply on pre-order this month.
probably I got confused because NI Komplete is on pre-order at the moment and was announced the same day as VE Pro 6.
Re: DP 9.1 is here
Just to add my experiences of introducing VEP6 to DP9.1 today..
Upgrading VEP was easy, but launching for the first time on both MacPro and MBP machines was a nightmare - VEP froze or crashed loads of times while validating plugins - mostly the VST's, the AU's pretty much validated fine. Got there eventually though
Once everything was running, as mentioned above, I also had issues with the buffer settings. I agree with others that the VEP should be set to "4 buffers". Even then I found the audio breaking up when DP buffer size is set to anything less than 512. At 512 and higher audio seems solid. (Incidentally Logic seems to need a minimum buffer size of 1024 so 9.1 is a winner there!)
Freezing seems to work OK too, but I've only tested so far with single instances of Omnisphere and Spitfire Sable strings in VEP and no time at the moment to check for larger templates/setups...
BTW I have to say I'm loving the latency improvement/snappiness in 9.1![happy :dance:](./images/smilies/dance.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
- corbo-billy
Re: DP 9.1 is here
Another detail: the Import Audio (Command F1) don't work fine (File selection problem) _
Imac M1 24" under Monterey 12.7 & Kontakt 7.6. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ MIDI Express XT _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.22 _
Re: DP 9.1 is here
Anyone running the new DP 9.1 on older machines? I currently running 8.07 on a 2x2.66 GHz 6-Core with 48 GB ram, I'm wondering if it's worth upgrading and will the new DP run as smoothly as 8.07 does for me.
Re: DP 9.1 is here
Working OK for me...corbo-billy wrote:Another detail: the Import Audio (Command F1) don't work fine (File selection problem) _
Re: DP 9.1 is here
It's blazing on my machine (see sig below). 9.1 does seem to have a few glitches though so I'd suggest waiting for MOTU to fix the obvious ones (e.g. controllers/event chasing). You could always go up to 9.02 in the meantime, that is really stable. Hope this helps...red1 wrote:Anyone running the new DP 9.1 on older machines? I currently running 8.07 on a 2x2.66 GHz 6-Core with 48 GB ram, I'm wondering if it's worth upgrading and will the new DP run as smoothly as 8.07 does for me.Thanks!
Re: DP 9.1 is here
Yes! Me three. Perhaps its an old guy thing. We want to make use of every second. Since we have so few left.Shooshie wrote:Me, too. Since the early days of Performer, I've worked on a sequence while playing it back. I'd often get my edits done while the client was still listening to it. Sometimes someone would ask "how long will it take you to get all those little problem spots fixed?" I'd reply, "I'm done."
Shoosh
Re: DP 9.1 is here
Me four!!labman wrote:YEs! Me three. Perhaps its an old guy thing. We want to make use of every second. Since we have so few left.
Re: DP 9.1 is here
I'm on a 2010 2.8Ghz Quadcore Mac. I guess you could call that old. 9.1 is fine on my system.red1 wrote:Anyone running the new DP 9.1 on older machines? I currently running 8.07 on a 2x2.66 GHz 6-Core with 48 GB ram, I'm wondering if it's worth upgrading and will the new DP run as smoothly as 8.07 does for me.
http://www.davepolich.com
Re: DP 9.1 is here
Notwithstanding new bugs, it runs better than previous versions on my 2009 i7 iMac.David Polich wrote:I'm on a 2010 2.8Ghz Quadcore Mac. I guess you could call that old. 9.1 is fine on my system.red1 wrote:Anyone running the new DP 9.1 on older machines? I currently running 8.07 on a 2x2.66 GHz 6-Core with 48 GB ram, I'm wondering if it's worth upgrading and will the new DP run as smoothly as 8.07 does for me.
- Shooshie
Re: DP 9.1 is here
Hot dog! I just got two emails from MOTU telling me that 9.1 is available!
hehehe...
Of course, it DID occur to me that maybe it's 9.1.1 or something. That would be amazing. But I think it's 9.1, just now getting here. These InterTubes are slowing down to US Mail speeds!
Shoosh
hehehe...
Shoosh
