Loading EXS24 instruments into MachFive
Hello there,
I saw in a Groove3 tutorial that in order to load the EXS24 instruments into MachFive the .exs instrument AND the samples need to be in the same folder.
Is there a way to avoid this, some sort of work-around?
Thanks in advance!
Thanks in advance!
Re: Loading EXS24 instruments into MachFive
Not that I've ever been able to find. I usually save these immediately as MachFive patches, then it's not an issue.
Thanks a lot, I'll try that.
Are there differnt versions of exs files?
When I double click an exs file in the m5 browser nothing happens.
Same with nki ? Is there a special import procedure ?
I just open exs files. Make sure it is in the same folder as the samples. For nki, only some will work and only up to V4 files.
Will do, thanks bayswater!
You're welcome, but I was answering AnSolas' question about whether there is a special way to import EXS and NKI files.massimosammi wrote:Will do, thanks bayswater!
Does exs import only works on OS X ?
I have a lot Instruments here which I have sampled with Redmatica Autosampler some years ago. However I can't import any of these created nki or exs under windows.
I don't have any windows based computers running, so I can't say, but I'd expect that would be explicitly mentioned in the manual.
[SOLVED]
Heureka!
This works for me:
Right click on a Program slot.
Load Program
Select nki
When i select a exs MachFive crash immediately
Heureka!
This works for me:
Load Program
Select nki
There is no batch import no ?
Or is there a way to define a search folder for missing files ?
I get each time missing samples when I import nki and eacjh time i need to point manually to a folder :/ I even tried copying all samples to the same folders as the nki files which not work heh.
I haven't come across a means of batch convert or search. I just bring in NKI end EXS24 and .KRZ files at the time I need them, and then save them as MachFive programs for future use.AnSolas wrote:There is no batch import no ?
