shortcut for window tabs
monsieurescargot
Post by monsieurescargot »
Hi,
Anyone found a way to shortcut into the different windows tabs in the main workspace?
toggle between track/sequence/drum/MIDI/quickscribe/mixer/...etc
I can't find it in the commands listing
thanks for your help
OSX 10.13. 16gig ram. UFX, Traveler mk1, Pulse16mx, DP10 , Live9, Nord Stage2, Sh101tubbutec, PolyEvolver Rack,Slim Phatty, MIDI Express XT, RYTM, AnalogKeys,Digitone, EmaxSE rack, Daking Pre/Eq, Tanzbar, tr606, SP16, s612, Neutron, TT303, EPS16+, Parva, p600Gligli, Biscuit, mcf42, therapsid, modules, seqV4
carrythebanner
Re: shortcut for window tabs
Post by carrythebanner »
There's not, unfortunately.
You can sort of approximate it if you configure the Consolidated Window to use a maximum of 1 row in the body section; when you invoke the windows' normal keyboard shortcuts (Shift-S, Shift-T, etc.) the new window will replace the old one.
frankf
Post by frankf »
I use window sets for this with key commands set to numbers 1-0 on the mac keyboard.
Frank
Frank Ferrucci
http://www.ferruccimusic.com
Why we're on this... why can't the user decide what tabs get used and what tabs don't in the Consolidated Window? I don't need DRUM and I don't need SONG. THis is kind of like the color schemes issue. No reason it cannot be implemented yet it remains a fixed aspect of DP.
This is the only reason I don't use that feature. :mumble:
