questions re installing DP7
GMT
Post by GMT »
I've acquired a Macbook Pro (6,2) which is a bit of a change from the now defunct G5 (PPC, OS4.11, DP4.61). I'll be working with OS 10.6.6 & DP 7.21 (might go to 7.22 later). I'm going to search through the DP tip sheet, but if someone can provide answers to a few questions, it might save some time.
Does the conventional wisdom still apply regarding remove isight plugin, get LAME framework; or do these no longer apply?
Is it still recommended that DP have it's own living space (partition) on a drive, or is this no longer regarded as best practice?
Any other bits of wisdom that I may need to know regarding this transition?
I've already considered backup methods recommended in another previous post.
Thanks,
Greg
if it sounds good, it is good - ellington
macbook pro 2.53 4G OS 6.8 DP7.22 828mkII
1nput0utput
Re: questions re installing DP7
Post by 1nput0utput »
Just use your installation disc to install it on the system volume. Then download and install updates from motu.com.
GMT
Post by GMT »
For those who are using an older version of DP (4.5), and are experiencing crash on quit, the isight plugin may be an issue. Tech note from Motu website:
http://www.motu.com/techsupport/technot ... erm=isight" onclick="window.open(this.href);return false;
zandurian
Post by zandurian »
LAME framework still applies. Upgraded to intel and didn't think of it till a client asked me to email an mp3 to someone right after a session and I was like, oops :oops:
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
zandurian wrote:LAME framework still applies. Upgraded to intel and didn't think of it till a client asked me to email an mp3 to someone right after a session and I was like, oops :oops:
Yep - no problems with it, works well and integrates seamlessly.
I have not heard of anyone having the iSight issue on OS 10.3.8 or later.
