Make a Mac Pro always boot into 32 bit mode?
I know, it's an awkward title for a post. I've been spending the
day setting up my new MacPro Quadcore and installing drives, memory,
my new UAD-2 Solo card and software.
Is there a way to get a new MacPro to always boot in 32-bit mode?
The 2010 Mac Pros (like mine) default to 64-bit when booting. But
lo and behold, today I discovered that the UAD-2 card isn't recognized
if you're running in 64-bit mode. You have to boot into 32-bit or the card doesn't work (the UAD Control Panel just reports "No
Cards Found"). The UA website says this is a known issue, but no fix
at this time other than 32-bit boot.
I know you can boot 32-bit by holding down the "3" and the "2" keys
while starting up the Mac. Curious if there's a more "permanent"
solution.
solution.
http://www.davepolich.com
Re: Make a Mac Pro always boot into 32 bit mode?
Here
It boots into whatever kernel you choose.
Found this by googling "terminal mac boot 32 bit mode". There are terminal commands.
To set your machine to boot into 64 bit mode enter this command and reboot:
sudo systemsetup -setkernelbootarchitecture x86_64
To set your machine to boot into 32 bit mode enter this command and reboot:
sudo systemsetup -setkernelbootarchitecture i386
This is for people who get a bit intimidated by the Terminal... it's the same exact thing in a GUI.bayswater wrote:Found this by googling "terminal mac boot 32 bit mode". There are terminal commands.
Thanks for this tip! I am indeed one of those people who is very intimidatedi7user wrote:This is for people who get a bit intimidated by the Terminal... it's the same exact thing in a GUI.bayswater wrote:Found this by googling "terminal mac boot 32 bit mode". There are terminal commands.
by the terminal.
You don't have to do much. Highlight the command, copy, open terminal, and paste and press return.
There's commands that have to be done in such specific formatting that simple copy paste techniques can cause problems... but on this specific command, no.bayswater wrote:You don't have to do much. Highlight the command, copy, open terminal, and paste and press return.
Where do i put in the 32 bit Command?
Thank You
Thank You
Open Terminal, found in your Utilities folder.
The simple way:
http://macstuff.beachdogs.org/blog/?p=134" onclick="window.open(this.href);return false;
A more complete explanation:
http://macperformanceguide.com/SnowLeopard-64bit.html" onclick="window.open(this.href);return false;
The simple way:
FYI, from the UA website, just in case you missed this:David Polich wrote:I discovered that the UAD-2 card isn't recognized
Changes in version 5.8.0
New UAD-2 plug-in: UAD Studer A800 Multichannel Tape Recorder
New UAD-2 plug-in: UAD SSL E Series Channel Strip
New UAD-2 plug-in: UAD SSL G Series Bus Compressor
(Mac) UAD-2 drivers are now compatible with 64-bit kernel mode
(Mac) Mac OS 10.4.x "Tiger" is no longer supported
Here's a handy little app: SixtyFourSwitcher 1.2. You can get it at Macupdate or google it.
Octo 2.8/10.6.4/DP7.21/PCI Driver 1.5.38352/BLA HD192s/UAD-1e & 5.50 plugs/Waves v7/Current/PSP/Altiverb6.3.5/Breverb1.5.8/Stillwell/Fabfilter/elysia/Brainworx
