Ethno 2
- mhschmieder
Re: Ethno 2
You might check the Mach 5 forum to answer that question. I think others had talked about using Mach 5 to load MOTU Symphonic Instrument as workaround until a Snow Leopard compatible release is available.
Re: Ethno 2
Another solution heremwalthius wrote:I have the original Ethno and have been patiently waiting (like so many others) for an update that will run on Snow Leopard. This business of REQUIRING the upgrade purchase has me PISSED. Not to say that I wouldn't get Ethno 2 at some point, but I bought the original Ethno in good faith, understanding that I'd purchased an instrument that I'd be able to use until something happened like MOTU went out of business. What they've done is absolutely -----.
I managed (somehow) to disable Ethno since it was crashing DP every time it loaded. Is there a way to access the Ethno sounds via Mach Five 2, while using DP 7.1 and SL?
http://www.motunation.com/forum/viewtop ... =5&t=40620
Re: Ethno 2
Symphonic Instrument does work with Snow Leopard, what do you mean?
I just got a UPS notification from MOTU that my Ethno 2 has shipped!!!!!
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
- mhschmieder
Re: Ethno 2
Sorry, I thought I had read in another topic that MSI was going to be the last to get updated, but that was probably regarding Version 2 vs. SL compatibility.
