Having problems with MSI and OSX 10.4.11
Trying to install MSI after a long time not using it and am having no luck. Funny i remember no problems before.
Have tried various things Re and De installing numerous times. Loaded everything from my 2 install discs then when that did not work downloaded the MSI installer from Motu but still no luck.
The standalone opens but immediately says "MSI has quit unexpectedly" (code below) and inside DP on startup it says "could not find application bundle" and then MSI is the only one of my plugs that will not show up.
Could my Ilok have gone bad?
ANy help greatly appreciated.
George Miller
MacBook Pro 15" OSX 10.4.11, DP 6.02, MSI 1.1.3
Here is the code when trying to load the standalone if anyone can figure that out:
Date/Time: 2009-12-04 00:21:49.569 -0800
OS Version: 10.4.11 (Build 8S2167)
Report Version: 4
Command: PluginHooksSA
Path: /Applications/MOTU Symphonic Instrument/MOTU Symphonic Instrument.app/Contents/MacOS/PluginHooksSA
Parent: WindowServer [63]
Version: 1.1.3 (1.1.3)
PID: 359
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Thread 0 Crashed:
0 <<00000000>> 0x00000000 0 + 0
1 com.motu.msi 0x0000a1e1 start + 8785
2 com.motu.msi 0x0000809e start + 270
3 com.motu.msi 0x00007fb9 start + 41
Thread 1:
0 libSystem.B.dylib 0x90047dd7 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90ce1da5 TSWaitOnSemaphoreCommon + 163
2 ...ple.CoreServices.CarbonCore 0x90ce8d8d TimerThread + 87
3 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 2:
2 ...ple.CoreServices.CarbonCore 0x90cec9e9 DeferredTaskThread + 57
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00007fc8 ecx: 0x01800038 edx: 0x005376c0
edi: 0xbffffd3c esi: 0xbffffd9f ebp: 0xbffff728 esp: 0xbffff70c
ss: 0x0000001f efl: 0x00010286 eip: 0x00000000 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x40fff com.motu.msi 1.1.3 /Applications/MOTU Symphonic Instrument/MOTU Symphonic Instrument.app/Contents/MacOS/PluginHooksSA
0x605000 - 0x669fff [Unknown Bundle] [Unknown Bundle]
0x7f2000 - 0x7f5fff com.apple.LiveType.component 2.1.3 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1092000 - 0x10f7fff com.apple.LiveType.framework 2.1.3 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x111f000 - 0x1165fff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x116a000 - 0x116dfff Motion /Library/Frameworks/Motion.framework/Versions/A/Motion
0x1244000 - 0x124cfff com.apple.iokit.IOUSBLib 2.7.5 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x8fe00000 - 0x8fe4afff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x90171fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901c1000 - 0x901c3fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c5000 - 0x90202fff com.apple.CoreText 1.1.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90229000 - 0x902fffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031f000 - 0x90774fff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9080b000 - 0x908d3fff com.apple.CoreFoundation 6.4.10 (368.33) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90911000 - 0x90911fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90913000 - 0x90a07fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a57000 - 0x90ad6fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aff000 - 0x90b63fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bd2000 - 0x90bd9fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bde000 - 0x90c51fff com.apple.framework.IOKit 1.4.8 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c66000 - 0x90c78fff libauto.dylib /usr/lib/libauto.dylib
0x90c7e000 - 0x90f24fff com.apple.CoreServices.CarbonCore 682.28 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f67000 - 0x90fcffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91008000 - 0x91047fff com.apple.CFNetwork 129.22 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9105a000 - 0x9106afff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91075000 - 0x910f4fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9112e000 - 0x9114cfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91158000 - 0x91166fff libz.1.dylib /usr/lib/libz.1.dylib
0x91169000 - 0x91308fff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91406000 - 0x9140efff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91415000 - 0x9141cfff libbsm.dylib /usr/lib/libbsm.dylib
0x91420000 - 0x91446fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91458000 - 0x914cefff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9151f000 - 0x9151ffff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91521000 - 0x9154cfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9155f000 - 0x91633fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166e000 - 0x916e1fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9170f000 - 0x917b8fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917de000 - 0x91829fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91848000 - 0x9185efff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9186a000 - 0x91884fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9188e000 - 0x918cbfff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918df000 - 0x918ebfff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918f2000 - 0x91932fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91945000 - 0x919f7fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a3d000 - 0x91a53fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a58000 - 0x91a76fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a7b000 - 0x91adafff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91aec000 - 0x91af0fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91af2000 - 0x91b7afff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b7e000 - 0x91bbbfff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91bc1000 - 0x91bdbfff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91be0000 - 0x91be2fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91be4000 - 0x91cc2fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91cdf000 - 0x91cdffff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91ce1000 - 0x91d6ffff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d76000 - 0x91d76fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91d78000 - 0x91dd1fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91dda000 - 0x91dfefff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91e06000 - 0x9220ffff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92249000 - 0x925fdfff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9262a000 - 0x92717fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92719000 - 0x92797fff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x927d8000 - 0x92a08fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92b22000 - 0x92b39fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b44000 - 0x92b9cfff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92bb0000 - 0x92bb0fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92bb2000 - 0x92bc2fff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bd1000 - 0x92bd9fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bdf000 - 0x92be4fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92bea000 - 0x92c7bfff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c8f000 - 0x92c92fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c95000 - 0x92cb3fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cc5000 - 0x92ccbfff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cd1000 - 0x92d34fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d58000 - 0x92d99fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92dc0000 - 0x92dcdfff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92dd4000 - 0x92dd9fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92dde000 - 0x930d3fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931d9000 - 0x931e4fff com.apple.opengl 1.4.16 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93c8d000 - 0x93d08fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93d41000 - 0x93dfafff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e3d000 - 0x93e3dfff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93e3f000 - 0x94000fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94046000 - 0x94087fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9408f000 - 0x940c9fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x940ce000 - 0x940e4fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94305000 - 0x94623fff com.apple.QuickTime 7.6.0 (1290) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x966f8000 - 0x9672efff com.apple.audio.MIDI.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x96afe000 - 0x96afefff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97169000 - 0x9716efff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x98472000 - 0x993eefff com.apple.QuickTimeComponents.component 7.6 (1290) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9ff45000 - 0x9ffe5fff com.apple.QuickTimeImporters.component 7.6 (1290) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
Model: MacBookPro1,1, BootROM MBP11.0055.B08, 2 processors, Intel Core Duo, 2.16 GHz, 2 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 1.4.4
Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 1 incoming serial ports
Network Service: Built-in Ethernet, Ethernet, en0
Serial ATA Device: ST9500325AS, 465.76 GB
Parallel ATA Device: MATSHITADVD-R UJ-857
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
FireWire Device: Mobile I/O 2882 - FireWire Audio Interface, Boris Manufacturing Corporation, Up to 400 Mb/sec
George Miller
Report Version: 4
PID: 359
Thread: 0
Thread 0 Crashed:
Thread 1:
Thread 2:
Re: MSI will not work OSX 10.4.11
Look in /Library/Application Support/MOTU/MSI — do you see a file called "MSI.bundle" in there?buresmiller wrote:… inside DP on startup it says "could not find application bundle"
yes, that is there. It says that file is a protools plugin. Is that correct?carrythebanner wrote:Look in /Library/Application Support/MOTU/MSI — do you see a file called "MSI.bundle" in there?buresmiller wrote:… inside DP on startup it says "could not find application bundle"
Also in the MSI support folder are an alias that refers to the MSI.dat file and a folder called MSI performances.
GBM
It might be an iLok problem — it tends to be the culprit when I've seen crash logs that have very short, nondescriptive crash threads like the one you posted.
Check out this tech note; it specifically mentions 10.4.9, but perhaps your issue is basically the same?
http://www.motu.com/techsupport/technot ... os-10-4.9/
Similar issue with me and fixed it a few nights ago . . . after a couple of years of no problems, MSI would only work in stand-alone mode and crashed as a plug. After moving the MSI folder out of a MOTU folder that I created for all MOTU apps and putting on the root level of my mac's applications folder, everything now works fine. Using DP 6.02 and 10.6.2
DP 11
iMac M1 (24-inch, 2021) 16GB RAM
OS X 11.6.2
yeah I saw that tech note and it looks like a very similar problem. Have thought about going through the rigamarole of a complete system reinstall BUT I was planning on upgrading to Snow Leopard at some point anyways, so maybe this is the time to do it and then see if I can get MSI working with it.carrythebanner wrote:Re: MSI will not work OSX 10.4.11
by carrythebanner » Mon Dec 07, 2009 10:47 pm
Thanks for your help.
GBM
Hmmm... I will ponder in the meantime a topic header which isn't exactly true in the literal sense.
Re: Having problems with MSI and OSX 10.4.11
There... edited the header... much better.
You can try to use MSI Sounds in UVIWorkstation
http://www.uvisoundsource.com/uvi-works ... icles_id/8
You just need to create an alias to MSI.dat in /Library/Application Support/UVISoundbanks
Still MSI need to be installe as it's used to check MSI authorization.
Hope this helps.
Hope this helps.
The steps in that tech note don't involve a system reinstall — you can install the 10.4.11 combo update over an existing 10.4.11 installation and it will update the appropriate files without erasing the whole system. (Still not a bad idea to backup your system first, but you do that already, right?)buresmiller wrote:yeah I saw that tech note and it looks like a very similar problem. Have thought about going through the rigamarole of a complete system reinstall BUT I was planning on upgrading to Snow Leopard at some point anyways, so maybe this is the time to do it and then see if I can get MSI working with it.carrythebanner wrote:Re: MSI will not work OSX 10.4.11
GBM
