MX4 2.2 now on MOTU site...
Just saw it posted in MOTU's download area tonight.
Re: MX4 2.2 now on MOTU site...
The update notes say that it should now be able to Bounce to Disk in DP6 without freezing first.
Ugh, finally.... Now I can put my fish sticks back in the freezer and get the darn MX4 box out of there.carrythebanner wrote:The update notes say that it should now be able to Bounce to Disk in DP6 without freezing first.
Very cool... I'll be glad when MachFive 2 can do this!carrythebanner wrote:The update notes say that it should now be able to Bounce to Disk in DP6 without freezing first.
![Smile :)](./images/smilies/icon_smile.gif)
Thank you. I thought MOTU forgot about MX4. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- mikebeckmotu
Anybody tried it yet? I downloaded it but haven't had time to devote to installing and testing.
It's been working well for me. Actually, installing the update reminded me how much I like MX4, so I've created many new patches recently.mikebeckmotu wrote:Anybody tried it yet? I downloaded it but haven't had time to devote to installing and testing.
Thought this was an interesting comment on the site:
Even if it's just MOTUs!
Ken-
That's not something I'd typically expect from MOTU (sorry to say) even it is just marketing hype.. Problem is we need ALL the VIs to have performance like this !!!Power and efficiency
On a Dual 2.66 GHz Dual Core Mac Pro tower in our test lab, sixteen real-time instances of MX4 produce a reading of around 50% on the processor usage meter. If we switch them all to pre-render mode, the meter drops to near 0% and we can then instantiate 37 pre-rendered instances.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Ken-
My Gear: MacPro 2.8ghz Quad (2010), 12 GB RAM, 4 internal HDs, OS 10.6.5, DP 7.21, MOTU 2408mkIII, MTP AV
- Dwetmaster
I would assume that synthesis based VI's like MX4 will benefit more from Pre-Rendering than Sample based one. The fact that it doesn't need to reload all its samples when record engaged is an example.
Sounds great, and I'm sure there are some performance gains but there's more to this than meets the eye if you read the fine print. Sure... you can instantiate 37 pre-rendered instances, but what happens if you have 37 average density MIDI tracks routed to each of those instances and you press "Play?" My guess is your level meter won't stay "near 0%" then.kenrinc wrote:Thought this was an interesting comment on the site:
I'm not trying to be a naysayer, but obviously how many instances you can merely instantiate is relatively meaningless. How many instances can actually play back is the real-life statistic that matters. It would be interesting to know that. I imagine you'd get more instances for sure, but nothing on the magnitude that might be incorrectly assumed based on how many instances can be loaded when DP is not playing anything back.
Wow, I have to say I downloaded the demo for this guy and I'm quite amazed why I did not have this synth! When I do take the plunge to DP 6.01 I might take advantage of the offer.
Ken-
Ken-
- RCory
Is there some setting I'm missing? I get no difference in CPU performance with DP6.01/MX4 2.2 than I get with other versions..
I can find no reference to a "switching to Pre-Render Mode" in the manual...
- RCory
okay - duh - follow up - you have to close the instance of the plug's window and remove rec-enable
btw, nice! Makes my aging Dual 1.25 G4 like new again! *cough*
There is some remnant of rendered audio in the beginning of the song - ie I usually have an empty measure or two at the beginning of a sequence and I hear bits of MX4 audio in this... not sure what to do about that...
- MeisterEckhardt
Is the update worth it? What does it do better? I want to avoid messing with iLok like the plague. In fact, I'd rather have the plague than mess with iLok. If its worth it I'll do it but otherwise I'll stay away.
Meister
Meister
Mac Mini 2012 under El Capitan OS X with 16 GB RAM, Motu MIDI Express XT, Motu 828 MK II Firewire, Motu 8pre, Korg o1W/fd, Yamaha S80, TrapKat, Yamaha Birch Custom Absolute drums, lots of percussion, Roland VS-1680, Mics, Fender J Bass, hens, tamworth pigs, barn cats, one incredibly smart and lovable farm collie. (Animals great for sampling, no batteries required).
- MeisterEckhardt
LOL!!!!!!1nput0utput wrote:Ugh, finally.... Now I can put my fish sticks back in the freezer and get the darn MX4 box out of there.carrythebanner wrote:The update notes say that it should now be able to Bounce to Disk in DP6 without freezing first.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
