828 mk3 Hybrid- Constant issues with Sonoma..
Hi guys,
Im using an 828 mk3 via USB to my mac mini m2 pro, running Sonoma 14.4.1. & Logic pro 10.8.1
Kernel extensions & lower security enabled on mac.
Since getting the M2 i have had nothing but issues, the 828 being just one:
MOTU driver regularly crashes Logic & the Mac (sometimes when the 828 isnt on)
Crackles / pops in mix bounces
Warnings about incompatibility between macos & Motu
Half the time logic doesnt recognise 828 when booting the interface.
Totally out of sync when first booting the 828 and playing in Logic.
Some instances of Sonoma i could control the volume of 828 with the keyboard, now that seems to have gone.
Absolutely no problems on my old intel machine.
I know some producers using exactly the same 828 & driver in ventura without any issues (whether thats coincidence idk)
Things i've tried/ trying are:
Disconnecting any other USB from the Mac
Different USB ports
Connecting the monitor via HDMI not USB
Support dont have a fix and taking weeks to come back every time.
Would love to hear if anyone else had similar issues and found a fix?
Cheers
Different USB ports
Cheers
Re: 828 mk3 Hybrid- Constant issues with Sonoma..
Try removing all of the MOTU driver files from your system. MOTU should have given you the list. If not there are older threads.
Install the 828 driver only:
The M2 does not require the MOTU driver unless you need to enable Loopback. In any case, if it works without the M2/4/6 driver, that's something you can report back to Support.
Before I sold my M2, I had no conflict between it and my 828mkII using that same MOTU Audio Installer I posted above over Sonoma 14.3. I never installed the M2 driver.
Yhere is a communication layer bug in macOS 14.4/14.41 that will be resolved in 14.5 but I have no idea if that is affecting the MOTU drivers other than I am not seeing problems here.
See if you still have a problem.MOTU Audio Installer
Mac v89555 | Oct. 13, 2021
macOS 14, macOS 13, macOS 12, macOS 11
Hi Mike,
Thanks for your reply.
Ive deleted everything except for - MOTU MIDI driver.kext- which couldn't be found.
Reinstalled just the audio installer- which is the only thing i ever do install when trying to reinstall for the 828. Not sure what the "driver" is then? Sorry if i said "driver" and confused matters.
However, this what ive done already when installing everything fresh on this new M2 computer, and from there had issues mentioned.
Will monitor but cant see how this is going to be a fix..
People have this running. The drivers do work. Apple has made it a bit of a pain to install them properly, however.gondola wrote: ↑Thu May 02, 2024 3:29 am Hi Mike,
It's possible that your Mac may not be set up to allow third party extensions. If you do not have Reduced Security enabled, the drivers will not load properly. Read this to see if it applies.
https://macsupport.tuxera.com/hc/en-gb/ ... based-Macs
Once that is done and you have run the MOTU Audio Installer, the following must be done within 30 minutes of installation.
https://motu.com/techsupport/technotes/ ... igh-sierra
If that doesn't do it, schedule a support call from MOTU. They can screen share and check the Activity Monitor for conflicting extensions that will need to be removed.
Hi Mike,
Reduced security on already.
And i dont get any message in privacy & security needing me to allow the extension after installing the motu audio installer.
Will try schedule a call with support as suggested....
Thanks for your replies
Hi,
I have had similar issues with my Ultralite MK3, just with kext installed and 14.4.x
Worked fine with the same driver on 13.x MacOS
It works ok on my M2 but when I upgraded my intel MBP 16 to 14.4.1 and tried the ultralite connected to a USB port the machine bricked itself and fried the logic board. I have noted this with Motu support and have heard nothing back once I gave them the full details they asked for weeks ago.
It seems 14.4.x MacOS and the Kext from MOTU are not very good combination.
Yup definitely something not right with the older motu interfaces and macos 14.
Funny how it worked on your M2 though and it isnt liking life on mine.
Same with motu support who just never get back.
Im pretty much done with this and im going to another manufacturer.
Looking around there are quite a few decent options available these days.
Will report back and conclude if it was/wasnt the 828 thats making studio life a misery
