I have an 828mk3 hybrid. The service recently changed the encoders as I was having problems switching on and the display was dim. After the repair there were clicks on Windows 10. The cpu not valid was there before the repair, but did not go anywhere after. On Mac there are no clicks and no problems when working with Logic. But this message and the clicks on Windows are frustrating me. I can't update the firmware, it says it can't see the device on both Mac and Windows, but Cuemix works fine. I would be glad to have your advice, I can't figure out where to look as I don't understand if it's a software or hardware problem.
The card is connected via USB. I have connected it to 2 computers and a laptop, but I have not been able to update the firmware.
Thanks.
I have had the Motu 828mk3 Hybrid since winter 2012.
Motu 828 mk3 Hybrid (CPU not valid update firmware)
Re: Motu 828 mk3 Hybrid (CPU not valid update firmware)
Power down and disconnect your unit from everything. On restart, the firmware version should flash. If v. 1.01, you are up to date and that isn't the problem.
Connect to the Mac and update if needed since that is giving you less grief. Here are the instructions:
Reset to factory default if necessary—this sometimes does it:
If out of date, you can download it from https://motu.com/en-us/download/828mk3 Hybrid Firmware
Mac v1.01 | Nov. 29, 2012
macOS 10.14, macOS 10.13, macOS 10.12, Mac OS X 10.11, Mac OS X 10.10, Mac OS X 10.9, Mac OS X 10.8, Mac OS X 10.7, Mac OS X 10.6
PC v1.01 | Nov. 29, 2012
Windows 10 64-bit, Windows 10 32-bit, Windows 8.1 64-bit, Windows 8.1 32-bit, Windows 8 64-bit, Windows 8 32-bit, Windows 7 64-bit, Windows 7 32-bit
Otherwise, are your drivers up to date? Download from the same site.828x, 828mk3 Hybrid, 896mk3 Hybrid, UltraLite mk3 Hybrid
Turn off the device.
Disconnect the FireWire (or ThunderBolt) cable from back panel if it is connected.
Connect the device to the computer via USB.
Press and hold the Page knob on the front panel and turn on the device.
Release the Page knob when the bootloader version number appears on the LCD.
Open the firmware updater program and follow the on-screen instructions to install the update.
828x / 828mk3 Hybrid / 828mk3 FW:
Press the Param/Setup knob until the LCD screen reads "828X SETUP" (or equivalent). The LCD screen will quickly flash to "LCD CONTRAST". Turn the Param/Setup knob all the way to the right. The LCD screen will read: "Factory Defaults Press [Value]". Push the Value knob. The LCD screen will display "Are you sure? Push [VALUE]". Push the Value knob again to confirm. The LCD screen will read: "Initializing...". The clock LED will flash when reset is complete.
Thanks, I'll try to do it the way you said.
