plug in alliance on v 10?
mikeharper
Post by mikeharper »
Anyone get Plug in Alliance BX plug ins to work on V10? Works on my other DAWS except DP. :x
(I can't update to v11 yet I have to finish a piece first).
DP10
Asus 490a, Win 10 pro,
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz LGA 1200
Samsung 970 EVO PLUS M.2 2280 Audio & sample drives
16G ram. MOTU 8A USB3-Thunderbolt
Re: plug in alliance on v 10?
mikeharper wrote: Wed Jun 15, 2022 8:10 pm Anyone get Plug in Alliance BX plug ins to work on V10? Works on my other DAWS except DP. :x
The hell you say. Many of us have been using them for years and many versions of DP.
You have to give us a clue — what plugs, what versions (VST2 or VST3)? Permanent licenses, subscription or both?
Have you contacted PA Support?
I use a few of the BX plugins in AU (see sig for configuration). I’ve never noticed any problems. As Mike suggests, something more specific about your problem might help. Config, versions, what did you do, what happened, do you see them in plugin preferences, etc.
mikeharper
thanks, I'll try a reinstall.
These are perm licenses I activated in samplitude. plugins are 14 plug ins including BX console master deck and others. All work in Cubase and samplitude. But DP reports a "serious issue on VST 2 and 3 and won't load.
I am at the end of a piece so its too intrusive to upgrade just yet. ill update findings.
DP10
mikeharper
unusual: a reinstall " fixed" it the statues says it still failed inspection but it loads and plays.
DP10
We need a Windows user with BX plugins to comment. I only use AU, and have noted that when I’ve tried a VST in DP 10, it has often failed, or caused crashes.
pencilina
Post by pencilina »
I've been using (and loving) them on windows in 11. I had the same issue with a few of them and honestly can't remember exactly what I did to get them working. I think I just ignored that message and re-enabled them in the plug in manger and/or loaded the the other VST version (3 or 2 depending on which one wasn't working). Hope that helps. Good luck.
