Page 1 of 4
Farewell to MachFive 3?
Posted: Tue Apr 12, 2022 6:34 pm
by Rick Cornish
Am I the only MachFive 3 user who didn’t know it doesn't run in Big Sur or Catalina?
I recently bought Falcon to replace MF3 and was going to just delete MF3 from my system until I remembered MF3 has the unique capability of generating .iso files from sample CDs and translating Kurzweil, Akai, E-mu (and more) samples to .ufs files that are readable by Falcon (and the free UVI Workstation). For someone like me who has dozens of sample CDs, many of which contain still-useful content, this is a very handy little tool to have around.
That’s when I discovered MF3 no longer works on my system, which is running Big Sur. The standalone version and the version that used to work from within DP both crash upon launch.
When I contacted MOTU, they wouldn’t **definitively** say MF3 has been abandoned, but two different support guys told me it's unlikely that they’d do further development on it.
“While I cannot 100% confirm, I would not expect there to be a compatibility update released any time soon.”
MOTU has clearly posted on their site…
MOTU Virtual Instruments and Big Sur or Later
MachFive, Ethno Instrument, BPM, Electric Keys, and Symphonic Instrument (any version) are not yet compatible with macOS Big Sur or later.
As a workaround, the UVI Workstation instrument (free) can read the soundbank libraries from all of these products and can be installed on macOS Big Sur.
I’m now in the process of trying to resurrect an old MacBook Air to run MF3 under High Sierra, just to translate sample CDs when I need them.
Anyone else in the same boat?
Re: Farewell to MachFive 3?
Posted: Tue Apr 12, 2022 6:48 pm
by James Steele
Yikes. It seems like more and more we're going to need to keep older Macs around for situations like this. I'm looking at getting a Mac Studio later this year (if all works out). I'm currently on Mojave. I've been busy lately doing the tedious work of opening projects and replacing instances of old plugs (many which don't work anymore) with their newer versions.
I don't know why MOTU is so cagey about MF3's status. I've been just assuming it was going to be a dead end. As I mentioned, I've been going through older projects and replacing every MachFive 3 instance I find with Falcon and then loading the instruments into that. (UVI just put out an update to Falcon a day or two ago, BTW.) Strangely, old projects that were using UVI Workstation load with the newer version of UVI Workstation, but often the instruments are missing. That's not really relevant to your post I guess. Just sharing.
I do know that when I do get around to transitioning to a Mac Studio, I'm going to be keeping my older Intel Mojave machine around for some time. It's crazy... I already have two cheesegraters in a closet that have been their for years... one is probably a G5. LOL. I need to recycle that or use it for a space heater. :P
Posted: Tue Apr 12, 2022 6:51 pm
by James Steele
Rick Cornish wrote: Tue Apr 12, 2022 6:34 pmI’m now in the process of trying to resurrect an old MacBook Air to run MF3 under High Sierra, just to translate sample CDs when I need them.
I do think MF3 will run under Mojave as well. It sucks that we continually lose capabilities in *new* software. I have an extensive database in Bento and for that reason I have a MacPro in my office that will never move past High Sierra unless I want to attempt to migrate the database over to something more cumbersome and less elegant.
Posted: Tue Apr 12, 2022 8:03 pm
by Rick Cornish
James Steele wrote: Tue Apr 12, 2022 6:51 pm
The old MacBook Air I have is a 2011 model that will only go up to High Sierra, which would be fine for MachFive 3, if I can get it working. I’ve been trying to rebuild it in recovery mode, but have been unsuccessful thus far.
Posted: Tue Apr 12, 2022 8:51 pm
by James Steele
I hear ya. Mind is a 2009 MacPro4,1 that was flashed to a 5,1 and somehow or another I have Mojave on it, but yeah... the older the OS the better when it comes to MachFive3. I can't even remember when it was last updated. Maybe you can build a HighSierra USB installer? Good luck!
Posted: Wed Apr 13, 2022 9:15 am
by mikehalloran
Rick Cornish wrote: Tue Apr 12, 2022 8:03 pm
Did you start with a new SSD? If not, that’s where to start. Make a bootable flash drive or external for the installer.
You may need to boot into Recovery first and reset the clock in Terminal to a date in 2017–18 before the OS will install. It will reset correctly after the OS is installed and you connect to the internet. I have the instructions somewhere if you need it.
Posted: Wed Apr 13, 2022 9:20 am
by Rick Cornish
mikehalloran wrote: Wed Apr 13, 2022 9:15 am Did you start with a new SSD? If not, that’s where to start. Make a bootable flash drive or external for the installer.
Thanks, Mike—as always!
I had a devil of a time finding a full installer for High Sierra and recovery mode didn't find the installer either. I finally found a link to the HS installer last night (had to download it on my 2013=vintage Mac Pro as my 2016 MacBook Pro wouldn't let me) and I'm building a startup USB drive with Install Disk Creator as I write this. 🤞🏻
Posted: Wed Apr 13, 2022 3:35 pm
by mikehalloran
Reinstall MacOS in Recovery Mode installs a copy of your current MacOS
Internet Recovery (spinning globe) will install the OS your Mac came with originally — if it was OS 10.7 or later. For most Macs, this means 2012. Your original MacOS can be checked at https://everymac.com/. There are some situations where Internet Recovery does not work.
If the Mac was reset using Configurator, Internet Recovery will install the latest MacOS. Been there recently.
Posted: Wed Apr 13, 2022 3:50 pm
by Rick Cornish
mikehalloran wrote: Wed Apr 13, 2022 3:35 pm Reinstall MacOS in Recovery Mode installs a copy of your current MacOS
Yeah.... Internet Recovery was a no-go. Said it "couldn't find the server" to reinstall HS. My bootable USB drive did the trick. The upshot is, I'm there now and did a test import, which worked flawlessly. The only hitch is MF3 requires iLok—and not an iLok license to the host computer, but a physical iLok itself, so I have to unplug the iLok from my Mac Pro in order to boot MF3 on my MBAir. It's a small inconvenience, but I'm back up with a MF3 conversion system.
Posted: Wed Apr 13, 2022 5:17 pm
by James Steele
Rick Cornish wrote: Wed Apr 13, 2022 3:50 pm
For older VIs like MachFive3 I think you can get by with the original style iLok dongle, yes? If so, I may have a couple laying around that one of the PACE folks gave me at a MOTU-MAC/MOTUnation NAMM dinner many moons ago. If you want, I can rummage around for one and mail it to you. I think I have some that have not been registered to any account yet. It could save you from having to do the swapperoo.
This reminds me... I lament how often it seems that "new, improved" software loses capabilities. I wonder why UVI couldn't have built that into Falcon?
Posted: Wed Apr 13, 2022 7:14 pm
by Rick Cornish
James Steele wrote: Wed Apr 13, 2022 5:17 pm For older VIs like MachFive3 I think you can get by with the original style iLok dongle, yes? If so, I may have a couple laying around that one of the PACE folks gave me at a MOTU-MAC/MOTUnation NAMM dinner many moons ago. If you want, I can rummage around for one and mail it to you. I think I have some that have not been registered to any account yet. It could save you from having to do the swapperoo.
Hey, James…..
Oh, man…. If you have a spare iLok laying around, that would be sweet. It’s not the end of the world to switch, but it’s a pain to have to wait while that old MacBook Air does it’s thing. I’ll PM you my mailing address in case you happen to find it. Thanks!
Posted: Thu Apr 14, 2022 5:18 pm
by James Steele
Hey, James…..
Mailed it today. Image
Posted: Thu Apr 21, 2022 1:10 am
by celestial
I've still got M5v3 working on Mojave, but just discovered that it crashes the new iLok version of VE Pro - unfortunately I have hundreds of old projects that may have to be revived if clients wish, which have M5v3 in VE Pro. The only way open these old projects is to delete the M5v3 component, then the old projects should still open with a blank space where M5v3 was in VE Pro.
I don't really use it much anymore, but have some nice old fx sounds from 20-30 years ago, some I made, some from E2 etc. I'm just wondering if anyone has any idea how to export M5v3 presets to something that can be read by UVI or even the MOTU nanosampler?
Posted: Thu Apr 21, 2022 8:47 am
by Rick Cornish
celestial wrote: Thu Apr 21, 2022 1:10 am I'm just wondering if anyone has any idea how to export M5v3 presets to something that can be read by UVI or even the MOTU nanosampler?
Instructions are on page 72 of the MachFive 3 user guide. Choose "Save Program and Samples" and MF3 will create a .ufs file of the program and a folder with the same name that contains any needed samples. You can open that .ufs file in UVI Workstation or Falcon.
Posted: Mon Apr 25, 2022 1:18 am
by celestial
Thank you Rick, so simple! I guess i should have looked:)
