resonance suppressor?
- Primary DAW OS: Windows
Please let me know how I can get rid of Harmoncia Resonance
What plugin should I use ?
Thanks in advance
Re: resonance suppressor?
Not sure what you mean by harmonica resonance? Sounds like you need an Equalizer.harmonicaman wrote: ↑Fri Feb 11, 2022 11:17 pm Please let me know how I can get rid of Harmoncia Resonance
Yes I was trying to use EQ to resolve this but not much success . Let me explainJames Steele wrote: ↑Sat Feb 12, 2022 3:40 amNot sure what you mean by harmonica resonance? Sounds like you need an Equalizer.harmonicaman wrote: ↑Fri Feb 11, 2022 11:17 pm Please let me know how I can get rid of Harmoncia Resonance
I play harmonica with guitar and as I use the harp in harmonica rack I can not hold it inside my hand therefore the sound is not round and it is thin
listen to this
I need to change this sound
https://soundcloud.com/user-962007871/h ... al_sharing
to this sound
Wonder if there is a plugin except eq that can make the life easier for me
Thanks in advance
I'm not sure I'd call that resonance - you just want to get that buzzyness out I guess? It's an EQ solution, but if a steep lowpass filter doesn't work, my first move'd be FabFilter Pro-Q and see if you can see the offending frequency and remove it. Any EQ that displays frequency would could do it, but Pro-Q lets you easily, and precisely isolate and grab just the buzzy frequency and pull it down.
Thanks I think I can get some results from EQ alone but that plugin is too expensive for me right nowdix wrote: ↑Sat Feb 12, 2022 12:27 pm I'm not sure I'd call that resonance - you just want to get that buzzyness out I guess? It's an EQ solution, but if a steep lowpass filter doesn't work, my first move'd be FabFilter Pro-Q and see if you can see the offending frequency and remove it. Any EQ that displays frequency would could do it, but Pro-Q lets you easily, and precisely isolate and grab just the buzzy frequency and pull it down.
Thanks in advance
DP's Masterworks EQ should suffice I'd think. Make sure the FFT Frequency Analysis is ON. You should be able to see the buzzy frequency to notch out.
