Hi folks.......
I recently checked out a couple mixing tutorials on Groove3. Two different mix engineers, both very accomplished and working in two different genrés, both highly recommended Cytonic "The Glue" as a mix buss compressor for its emulation of the SSL console compressor.
This plugin never goes on sale, and—before I spend $100 on it—I'm wondering if anyone has first-hand experience with it, and—in particular—how it might compare with the Native Instruments "Solid Bus Compressor", which purports to be essentially the same thing (and which I already own, since it comes with NI Komplete).
Thanks in advance for any insight you have on "The Glue" and/or "The Glue" vs. "Solid Buss Compressor."
"The Glue"
"The Glue"
- mothra
Re: "The Glue"
Never used the Solid Buss Comp, but The Glue comes with Ableton Live (along with a couple other ported Cytomic plugs), and Im still using the actual SSL bus comp instead. To be honest, 'The Glue' doesn't sound very different than the SSL or the Waves version, but in Ableton its heavier on the CPU than Waves or the SSL. Sometimes Ill swap the SSL for the Brainworx Townhouse Bus Comp depending on the track. The Townhouse is what became the infamous SSL comp, but its a bit different and REALLY punchy for lack of a better word. If its something hip-hop or drum and bass Im working on and I really want to make it hit, the Townhouse is the way to go, but it can be a little too much sometimes.
M2 Pro Mini, macOS 14, MOTU 828x/Ferrofish Pulse 16, Cubase Pro/MPC
Re: "The Glue"
Thanks, Mothra…. this is the stuff I was hoping to hear.
- sdemott
Re: "The Glue"
Just to offer another opinion, and having used a real SSL E/G+ with the bus comp, and all the different emulations, there are better bus compressors out there. I much prefer the SPL Iron (real or plugin) because it just does so many nice things to the mix.
There's nothing wrong with the SSL bus compression, but a lot of people are surprised at how uncolored it really is. It was meant to be a very transparent VCA compressor. It does it's thing without adding a lot of its own flavor. While other compressors can have more mojo.
-Steve
Not all who wander are lost.
