Hi all,
Looking to move over from my MacMini late 2012 to an M1 version soonish and just have a couple of questions for anyone who has jumped ship already...
I am assuming that if you've saved a bookmark for your MOTU's IP address in your browser then you can still access the interface's web application from an M1 Mac or just enter it directly in a browser and it's just the 'discover' application that is not working. From there I can set up cue mixes, sends, save/recall presets and all the usual stuff I do?
With an AVB interface operating under USB and core audio, does it revert a stereo in/out or do all the inputs and outputs still show in Audio MIDI setup?
Is this the same in Logic or Garageband?
Thanks all!
Accessing AVB interface from an M1 mac & 'core audio' functionality
- PhireAlly
Re: Accessing AVB interface from an M1 mac & 'core audio' functionality
Hi,
Below is a link to another thread where I've explained how I am able to get the MOTU Pro Audio Control web app to work on my M1 MacMini
using a MOTU 1248.
See the last two posts on page 1.
https://www.motunation.com/forum/viewto ... =2&t=68503
Hope that helps,
PhireAlly
using a MOTU 1248.
Hope that helps,
PhireAlly
MacMini M1, 8-Core @ 3.2GHz, 16GB Ram, MacOS 12.6.5 (Monterey)
MOTU 1248 - MOTU 16A - (2) MOTU 8A - Arturia AudioFuse - Antelope ZenGO
Studio One Pro 6 - Logic Pro 10 - Nuendo 12 - MOTU DP 11
Acustica - Antares - Apogee - Arturia - Blue Cat - Boz Digital - Celemony - Dolby - Eventide - FabFilter - Flux
HorNet - IK - iZotope - Kazrog - McDSP - Melda - Nomad Factory
Plugin-Alliance - Softube - Soundtoys - Tokyo Dawn - UAD-2_TB2 & PCIe
Valhalla - Waves v14
Thanks! Makes me a bit less nervous about making the switch.PhireAlly wrote: ↑Tue Mar 02, 2021 2:05 am Hi,
using a MOTU 1248.
Hope that helps,
PhireAlly
Joe
- PhireAlly
Hey Joe,
Also take a look at the thread below for more information on setting up an AVB interface using Apple's built-in AVB driver.
https://www.motunation.com/forum/viewto ... =2&t=68516
Hope this helps,
PhireAlly
Hope this helps,
PhireAlly
- PhireAlly
The Apple Core Audio Driver (using USB) has a maximum of 24 inputs and Outputs simultaneously with any MOTU AVB Audio interface.stripeyjoe wrote: ↑Wed Feb 24, 2021 3:50 am With an AVB interface operating under USB and core audio, does it revert a stereo in/out or do all the inputs and outputs still show in Audio MIDI setup?
The Apple AVB Driver (using Ethernet) gives access to all available Inputs and Outputs of your MOTU AVB Audio Interface.
Some or all Inputs and Outputs of your interface (depending on which driver you decide to use) will be available in any DAW that supports
Multi-Channel Audio, including Logic and Garageband.
PhireAlly
