Just to know if anyone has experience with this app from Intelligent Assistance
http://intelligentassistance.com/xtocc.html
This app transcode FCPX xml projects to FCP 7 xml that can be imported in applications as Adobe audition, After effects,... and in theory DP could also import these files
Import FCPX xml to DP with XtoCC app
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
Re: Import FCPX xml to DP with XtoCC app
What theory would that be?and in theory DP could also import these files
A number of DAWs support some form of .xml import but, as far as I know, DP is not one of them. MusicXML import has been on my wishlist since DP 8 shipped without it.
If there's something I'm missing here, please let us know.
Unfortunately does not work outmikehalloran wrote:What theory would that be?and in theory DP could also import these files
I bought the app and I have tried to import FcPX projects in format XML translated by XtoCC to DP. The results:
Some projects were successfully imported as FcP7 files in DP, but in other projects DP was not able to locate audiofiles. In spite I wrote the correct archive folder location in the warning window DP did not load it. I investigated if this problem was due to permissions issue (relocate the files to other HD etc..) but for some unknown reasons DP didn’t recognize it.
But worse still is the fact that these xml files are flawless imported in After Eff, Davinci R,...
Apps that support MusicXML import, I’m guessing.buhardilla wrote: But worse still is the fact that these xml files are flawless imported in After Eff, Davinci R,...
Thanks for reporting back.
I have used Logic Pro X which does support MusicXML import as a bridge between certain notation apps and DP. It works well enough but there are a lot of steps involved — direct import into DP would be easier. The $200 spent on Logic has paid for itself many times over even though I’ve never begun nor completed a project in it. Without knowing the details, why wouldn’t this approach work for you? Logic has a feature where you can export all audio and MIDI to the desktop simultaneously—I use it often and then select what I will open in DP.
Those I’ve talked to at MOTU don’t understand why anyone would be interested in MusicXML import—while touting .xml export as superior to MIDI.
I do have to agree with them on one point: They just don’t get it.
