Hardware outputs not detected?
- Kev
- Primary DAW OS: Windows
My audio interface has more than one stereo out, but DP is apparently only seeing the first one, as far as I can tell. The "Configuring Audio Devices" chapter in the Getting Started manual doesn't seem to cover this issue. Any suggestions?
Occasional user of DP(v9.52), Mainly using Cakewalk and Mixbus32C(4.3).
i7-13700|Gig-UD790-RD|UAD2octo+solo|Multiple-drives|MatroxC420|W11
Audient-iD44II+ASP800|Aphex141B|KRK-VXT6|+VariousOutboardGear|+guitars&basses|+MIDI-keyboards
Re: Hardware outputs not detected?
Did you look at the Bundles window in DP? I am familiar only with MOTU interfaces in Mac OS, which publish all i/o to that window, but I suspect your Audient may, too, if the proper driver software is installed.
- Kev
I haven't checked out Bundles yet. I'm still trying to wrap my head around the basic stuff. But if learning about Bundles will help, I'll look into that next. Thanks.
- Kev
The only hardware option in any track or bus output is "Analogue 1-2 (Stereo)".
Did you look into Bundles yet? The Bundles window is where one creates the i/o matrix for DP. Take a look if you haven't already done so.Kev wrote:The only hardware option in any track or bus output is "Analogue 1-2 (Stereo)".
- Kev
OK I've got it now. Thanks.
Do I need to set this up for each project? I was expecting the i/o settings to be global.
