On Velocity in the Source section
I'm learning how to create a preset. At page 17, section 38 to 41 you're supposed to control the filter envelope with On Velocity. I can't distinguish any difference when striking my MIDI controller key with varying strength. Any suggestions?
Windows 10, DP 11
https://www.youtube.com/channel/UCOI37x ... 8vAQJwNm_A
- FMiguelez
Re: On Velocity in the Source section
I´m not really clear about what your issue is...
Is it that, no matter how hard you strike the keys, they all come out with the same velocity in DP? If so, maybe your controller is not velocity sensitive. Or perhaps you must reset its action? Lots of keyboards have pre-made presets with different variations of keyboard action.
Or is it that your filter envelope is not responding to the different velocities? If so, then the problem must be with he way you're assigning that parameter to the velocity. We need more details...
It's working now. There was something with option-dragging that didn't work before.FMiguelez wrote:I´m not really clear about what your issue is...
Windows 10, DP 11
