Paste At Wiper
This forum is being developed and is intended as intended as a place to bring together various Digital Performer video tutorials. Currently only YouTube videos may be embedded using the [YouTube] BB code.
- Dan Worley
Paste At Wiper
I posted this when Paste At Wiper was first added to DP (I forget which version that was, maybe DP8). Anyway, I forgot to mention that you need to go into Setup > Commands, do a search for "wiper," and then set a key command for Paste At Wiper. In the video, I'm using the command I set up for Paste At Wiper (Command Option Shift W).
DP10.13
Re: Paste To Wiper
You don't sound anything at all like you look! ☺ Thanks for posting.
- Dan Worley
Re: Paste To Wiper
I don't look anything like I look either, and boy is that confusing when I get up each day.MIDI Life Crisis wrote:You don't sound anything at all like you look! ☺ Thanks for posting.
DP10.13
Re: Paste To Wiper
Weirdest freakin spam I've seen in a long time.
- Prime Mover
Re: Paste To Wiper
Great voice, dude. Wish I had a more interesting voice. I love singers with unique voices (huge Roine Stolte fan). Nice tip too, actually... I've never used paste to wiper before!
— Eric Barker
Eel House
Eel House
Re: Paste To Wiper
I've watched the video and it looks like you simply mention that you're "pasting to wiper".
I'm apparently too dense to see how you're doing this.
How are you doing this?
Thank you.
Thank you.
- Dan Worley
Re: Paste At Wiper
Hey, yeah, that would be helpful now wouldn't it?fgagne wrote:I've watched the video and it looks like you simply mention that you're "pasting to wiper".
Thank you.
Go to Setup > Commands and search for "wiper." You will see it there and you can assign your own command to it. There's also Merge at Wiper and a few other ones.
DP10.13
Re: Paste To Wiper
When Smart Selections is on, Paste to Wiper pastes at the same relative position as the source, rather than exactly at the wiper.
DP8.07
DP8.07
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
- Dan Worley
Re: Paste To Wiper
Yes, that's pointed out in the video. Very handy.reedster wrote:When Smart Selections is on, Paste to Wiper pastes at the same relative position as the source, rather than exactly at the wiper.
DP8.07
DP10.13
- FMiguelez
Re: Paste To Wiper
What I see here is that the above is true as long as there is NO current selection. If there is one, DP will ignore the wiper and paste at the beginning of the selection, even if Smart Selections are on. This applies exactly the same for the insertion point as well.Dan Worley wrote:Yes, that's pointed out in the video. Very handy.reedster wrote:When Smart Selections is on, Paste to Wiper pastes at the same relative position as the source, rather than exactly at the wiper.
DP8.07
Actually, the only way I can get it to paste at the wiper location is if I press command-D (to get rid of any selection) just before pasting, so there's nothing selected. Otherwise, it'll paste right over the copied region.
- Dan Worley
Re: Paste To Wiper
Weird! I just tested it with both audio and MIDI selections, and what you're describing is not the case here. When I do the command for Paste At Wiper (I use Command Option Shift W), it deselects any selection and pastes right at the wiper, or if Smart Selections is active it pastes to the relative position.FMiguelez wrote:What I see here is that the above is true as long as there is NO current selection. If there is one, DP will ignore the wiper and paste at the beginning of the selection, even if Smart Selections are on. This applies exactly the same for the insertion point as well.Dan Worley wrote:Yes, that's pointed out in the video. Very handy.reedster wrote:When Smart Selections is on, Paste to Wiper pastes at the same relative position as the source, rather than exactly at the wiper.
DP8.07
Maybe try a relaunch of DP. That can clear up some strange behavior.
Good luck.
DP10.13
- FMiguelez
Re: Paste To Wiper
Dan!Dan Worley wrote: Weird! I just tested it with both audio and MIDI selections, and what you're describing is not the case here. When I do the command for Paste At Wiper (I use Command Option Shift W), it deselects any selection and pastes right at the wiper, or if Smart Selections is active it pastes to the relative position.
For Tlaloc's sake! You're totally correct!
I watched your video, and I thought you simply were demonstrating how to regularly paste (with normal paste) to the wiper location. Duh!
I didn't even know this Paste to Wiper command existed in DP at all (thus my confusion). So, thanks to you, I just learnt this neat thing to do in DP.
I just assigned a key command and tried it. It works great!
This happened one time to me with Mike Halloran, and now with you. So, today's lesson is (besides this great new trick), next time something in my mind seems to contradict what Mike Halloran says about hardware, or you about DP, I should really recheck my facts first
So thank you, my friend!
What I wrote about regular pasting still holds down here, though. But this new command will now see a lot of usage in my sessions.
- Dan Worley
Re: Paste To Wiper
So pleased to help in any small way, Fernando.
And, by the way, I did not make it clear in the video what I was doing at all. If it were me watching it, I would have been screaming at the screen. I just assume everyone reads the New Features List and would know about it. My mistake. I cleared it up in the first post.
Thanks for not telling me off.
DP10.13
Re: Paste At Wiper
Looks like this video is missing now too? I'll delete if that's the case.
Re: Paste At Wiper
Yep...
