MX4 and volume
Posted: Fri Nov 05, 2010 3:30 pm
Hi,
I'm trying to do a simple mix thing: put a volume "fade" on an MX4 patch (I'm using it as a plugin within DP 7.21). The patch is Bank 14 Stings; Patch 1 Matthew Strings. It's too loud and eating up some delicate parts. I've tried the usual: setting it at a VERY low initial volume (e.g. 25!) - gee, drawing in a CC volume fade, decreasing the initial velocity... nothing. It's still too loud and isn't affected by anything I do. Yes, auto is on. Yes I've tried quitting DP, restarting, doing a cold restart. No difference. Sometimes I do get annoying gremlins with the mixer - things don't "register" and do what they're supposed to until I restart, but this is ridiculous. I just took off auto and while the single held MX4 note was playing pulled the fade down to zero but nothing changed - I still heard the note at full volume the whole time. BTW: I successfully have pitch bend implemented. That works. Then it occurred to me, in addition to possible human error, or the usual mixer voodoo, what if the patch simply didn't respond to volume? Is that possible? After spending 2 hours on this is there anyone who can tell me if this is the case or how I could get this patch to respond to simple volume info??? I've used the patch a number of times and can't remember running into this kind of stupidity.
Thanks,
Joel
Thanks,
Joel
