Ethno Does[n't] Work - [RESOLVED]
Throatsinger
Post by Throatsinger »
Hi,
I purchased Ethno a week ago. Still can't get it to work. Bad/slow tech support, incorrect install instructions, no phone support (always busy, have tried for hours at a time)... Grrr! I've been a customer for many years, and it was never so bad!
Now the program gives me two DAT files not found, for both valid sound data and valid loops volume from the Libraries/App support... of course, the instructions didn't say to put the files in the Library, just anywhere on the hard drive. Moving them to the Library doesn't fix it.
Any good advice would be greatly appreciated.
Re: Ethno Doesn't Work
Ummm... what platform? Mac? Windows?
Throatsinger
Oops! Imac 2.8, running OS 10.5.6
Thanks,
Steve
Throatsinger
Finally got through to MOTU tech support and got it working.
joelfriedman
Post by joelfriedman »
Hi,
I've got similar problems. I can't install Ethno at all. I keep getting "error code -36" when I try to install from the disk. I've tried different optical drives etc. No go. The UFS file *almost* installs - and then hangs at the last minute - but the dat file won't even start. I've emailed Motu but haven't heard back from them. I saw somewhere online that others had a similar problem and had defective install disks. I guess it's time call Motu... Curious what they told you.
Mac Pro 2x2.8GHz, OS 10.5.6, 16GB RAM, 500 GB boot and sample HD's, UltraLite
DP 6.0.2, MachFive 2.02, MX4 2.2, Ethno (not working...), Sibelius 5.2.5, installing Kontakt 3
Joel
Joel Friedman
iMacPro 2017 3.2 GHz, OS 13.6,3 32GB RAM, 4 1 TB HD's (boot, project, and samples), MOTU UltraLite MK4, Nektar Impact LX88
DP 11.3, MachFive 3.2, MX4 2.2, Ethno 2.01, Komplete 14 Ultimate (don't ask...), Sibelius Ultimate, Symphobia v. 1.06, assorted libraries...
MacBook Pro M1 16 GB RAM OS 13.6.3
Throatsinger wrote:Finally got through to MOTU tech support and got it working.
Care to share how? It would probably be helpful to others here who might encounter the same issue.
Dragonwind
Re: Ethno Does[n't] Work - [RESOLVED]
Post by Dragonwind »
I would like to know how because I moved the location of the data sounds and now I have these errors. I thought there was a way to tell Ethno where the folder was
but can't remember how to do it and so far my manual is M.I.A.
Chris
https://www.christophercaouette.com
dp11, LP, C12, Nuendo 11, OS 12 latest version, MacPro 6,1 12 Core, 64gb RAM
mz9bzero
Post by mz9bzero »
yea, I was using Ethno 1, and it work fine until snow leopard . . .
they did not want to chat or email . . .
finally discovered the hard way . . .
ethno 1 was no longer their concern . . .
warning, be leary as you too could be kicked to the curb on this . . .
cheers
rodger1811
Post by rodger1811 »
mz9bzero wrote:yea, I was using Ethno 1, and it work fine until snow leopard . . .
cheers
Here's the problem.... Ethno 1 NEVER was supported on Snow Leopard and you weren't kicked to the curb. The problem is that you didn't properly research the issue before you purchased it. Why would you even purchase Ethno 1 when Ethno 2 is the latest version and DOES work with Snow Leopard? I think that you should accept responsibility for this one.
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
mz9bzero
Post by mz9bzero »
you are correct,
thank you.
