Motu 828 Mk3 Firewire and Ventura
- mothra
Re: Motu 828 Mk3 Firewire and Ventura
Are you expecting the audio to come from the Main Outputs? Cause that's not how you have the interface setup...
M2 Pro Mini, macOS 14, MOTU 828x/Ferrofish Pulse 16, Cubase Pro/MPC
And how should I set it?
Hi,
any news about it?
Thank you
any news about it?
Thank you
These controls should not be active when your interface is — yours are, however.
Take a look at the Input tab. Is the 828 selected there?
Why is the Audient showing as On? That may be your trouble. Turn it off, reboot and see what happens.
Ok, removed Audient and restarted, now it's like this, but I don't hear any audio
- IMG_5780.jpeg (2.28 MiB) Viewed 38844 times
Here's how it's set up
- IMG_5784.jpeg (4.57 MiB) Viewed 38836 times
- IMG_5783.jpeg (3.4 MiB) Viewed 38836 times
- IMG_5782.jpeg (4.24 MiB) Viewed 38836 times
And the connections, firewire, and two cables from analog outputs 1 and 2 to the monitors
- IMG_5787.jpeg (2.15 MiB) Viewed 38829 times
- IMG_5786.jpeg (2.14 MiB) Viewed 38829 times
- IMG_5785.jpeg (2.79 MiB) Viewed 38829 times
HI,
Can anyone please give me advice on how to setup the card for the audio problem?
Nic
Nic
HI,
I would be grateful if someone can help me, unfortunately I also tried to buy and use the adapter from firewire to thunderbolt 2 and from thunderbolt to thunderbolt 3 (usb-c) by connecting it to the usb-c port of the pc. In this case the Motu is not really seen.
Can anyone please recommend me a solution?
Thank you
Nic
Thank you
Nic
Using the adapters the Motu is not seen
- IMG_5788.jpeg (6.83 MiB) Viewed 38776 times
HI,
Has anyone had the same problem? How did it solve?
Thank you
Nic
Thank you
Nic
No help guys?
Nic
Nic
HI,
I can't get out,
Can you at least tell me if the outgoing and incoming connections are correct?
I have two jack cables that come out from analog out 1 and analog out 2 and go to my speakers. That's all for now, how should Motu Audio Setup be set?
Nic
I can't get out,
Nic
- Screenshot 2023-07-19 alle 14.26.09.png (75.86 KiB) Viewed 38614 times
