Zeno wrote: ↑Wed May 31, 2023 4:15 pmWhich gain stage do you mean? The PGA itself is the controllable gain knob (10-65dB) of the preamp, which always applies to mic signals, but by default also applies to the Line In signals. The PGA path is the upper path. So, if I read it correctly, it's the PGA path which adds the extra amp stage (i.e. the PGA), no? (Maybe the placement of the "PGA" label in the illustration is confusing; I take it to refer to the 10-65dB amplifier triangle).
PGA is shown direct to the PGA bypass switch, and it’s shown passing through the mic/line switch. 2 different paths.
