Lunacy Audio CUBE updated to v1.5.10
Kontakt 7.7.0 updated to 7.7.1
New version of Kontakt 7 is out. Just run Native Access. Gonna run a TM backup first. I'm still traumatized from Kontakt 7.6.1!!
Version 7.7.1 2023-11-21
ADDED
Preference to disable "New Instruments for you" panel in
Options > Interface
IMPROVED
Some info bar help text updated
FIXED
QWERTY keyboard and mouse events intercepted when
Kontakt is hosted as a plugin in Logic Pro
FIXED
Keyboard shortcuts not working in standalone
FIXED
Visual glitch when resizing Kontakt whilst hosted as a plugin in Logic Pro, and running at 75% zoom
FIXED
Crash when replacing loaded instrument if currently focussed instrument is in edit mode
Tracktion LOVE updated to v1.05
Run the Tracktion Download Manager to update.
AMEK Mastering Compressor updated from 1.1.0 to 1.1.1
This is just one that I own that I noticed tonight. Run PA-InstallationManager to update.
Valhalla updates
I saw a post that Valhalla has updated both SuperMassive and Room with new features.
https://valhalladsp.com
Vienna Ensemble Pro 7 updated from v. 7.3.3499 to 7.3.3502
Vienna Ensemble Pro updated.
Build (3502)
Hotfix macOS: Legacy MIR Pro would not process wet signal
IZotope/Exponential Stratus and Symphony reverbs updated
I share this here because I found out these had been updated. Prior to this update AAX was still Intel only. It turns out that relying on iZotope Product Portal to alert you and update these is not a good idea. I found I had to go get the installers from here:
https://www.izotope.com/en/products/downloads.html
Melda Plugins V 16.10
Kontakt 7.7.1 updated to 7.7.2
Version 7.7.2 2023-11-27
FIXED
Display and loading of files with special unicode characters
in Library tab
Plugin Alliance SPL Free Ranger updated from 1.18.0 to 1.18.1
Use the PA-Installation ManagerPlugin Alliance SPL Free Ranger updated from 1.18.0 to 1.18.1
Plugin Alliance ADPTR Audio Metric AB updated to 1.4.1
Not sure when this happened but I had 1.4.0 previously. Update via PA-InstallationManager
Altiverb 8 is out. Discussion of Altiverb 8 moved to new topic
Altieverb 8 is out. Discussion started up about this plugin in this "updates" topic. Altiverb 8 bears a lot more discussion so I took those posts her and merged them to this topic that had already started about Altiverb 8:
viewtopic.php?t=73668
Please discuss Altiverb 8 over there. Thanks!
Valhalla VintageVerb 4.0 is out! Free for registered 3.0 users!!
https://valhalladsp.com/shop/reverb/val ... tage-verb/
Here's the post I saw on Gearspace:
We’ve just released the ValhallaVintageVerb 4.0.0 update, with two new reverb modes: Chamber1979 and Hall1984!
Chamber1979 is inspired by a chamber algorithm from the late 1970s. The original design has been updated with lush & balanced modulation, a less metallic sound, and a smooth decay at all settings of the reverb time. We've also modeled the “aperture filter” of the original hardware, which adds brightness to the 70s and 80s modes, and makes things more properly vintage. Chamber1979 is great for vocal and acoustic chamber reverbs, as well as short room sounds and massive synth reverbs.
Hall1984 is a modern take on the classic concert hall algorithms of the 1970s and 80s. The internal reverb decay calculations have been updated to allow for more realistic shorter reverb times, as well as a more open sounding decay. Hall1984 also incorporates the aperture filter, which brings the tonality closer to the original 70s and 80s hardware. We feel that Hall1984 is the perfect expression of the VintageVerb philosophy: it looks to the past for inspiration, while incorporating modern reverb theory to add flexibility and clarity. Hall1984 sounds great on any audio source, and can be used for small rooms and giant cathedrals, as well as classic hall reverbs.
We’ve also added some QResque presets to the Palace presets folder, to showcase how the Palace algorithm can emulate early 80s digital room simulators. The Palace mode was released in January 2023, and we are still finding new tricks with it!
The 4.0.0 VintageVerb update is a FREE update for everyone that owns ValhallaVintageVerb! Wanna learn more? Check out the blog post. Already own ValhallaVintageVerb? Just log into your Valhalla user account and grab the installers.
ValhallaVintageVerb was first released in December 2012. Over the past 11 years, we’ve released a bunch of updates, adding 14 new reverb modes (for a grand total of 22), as well as new GUI color modes, AAX, VST3, and updates for M1/M2/M3 Macs. We’re really excited about the 4.0.0 update, and and want to thank everyone here at Gearspace for your support over the years!
Several Softube Deals
(Seen on GS. Hat tip augustenz)
Marshall Silver Jubilee 2555 for $15, code 2555JUBILEE: https://www.softube.com/marshall-silver-jubilee-2555
British Class A for $42, code TAKECLASSA: https://www.softube.com/british-class-a
Model 80 for $59, code SUPERMODEL59: https://www.softube.com/model-80-five-voice-synthesizer
Kontakt 7.7.3 is out today. It's probably fine... but I think I'll run Time Machine and get. a snapshot of my boot drive first!!
I'm a little gun shy when it comes to Kontakt after the 7.6.1 debacle!
ADDENDUM: Looks like this update is purely so NI can market to users. Ugh.
Version 7.7.3 2023-12-14
ADDED
First launch screen to direct new users towards free Kontakt Instruments
ADDED
Selecting a tag in Library Browser updates recommendations in "New Instruments for you" panel
