I have a MacBook Pro running OS 14.1 (recently installed by Apple during a logic board swap). I can see and monitor mic inputs in my Apollo 8 Thunderbolt, but have no mic signals present in DP 11.23. There's actually a very faint signal, but I suspect it may be coming from the MacBook mic. I have microphone access enabled in Privacy & Security. All other DP settings seem to be correct, as I can monitor my sessions through the Apollo as normal.
Anyone else running the same or similar setup? Wondering if DP is working properly with OS 14. Everything was fine before the new OS was installed.
Any ideas would be greatly appreciated!
No input from Apollo 8 Thunderbolt to DP 11.23
Re: No input from Apollo 8 Thunderbolt to DP 11.23
Hopefully someone using a UA interface can help. I'm running macOS 14.1.2 and not having any issues, but I'm using MOTU audio interfaces. You might try reinstalling any UA drivers.
OP did you ever get this resolved? I'm having a similar issue with no input coming from my Apollo into DP11.31 MBP 14.41
Everything works fine in Logic Pro.
John
MacBook Pro 2.9GHz i7 2017 500GB SSD. 16 GB RAM DP 9.51 UA Apollo Twin Quad Thunderbolt
Enable the Mic on installation?
