How to use the same interface (828es) with two computers?
Hello there.
I share a studio room and we're trying to work out a good setup for working.
We have a MOTU 828es racked that we should share to take advantage of the whole system. Of course we're not using it at the same time, it's one-at-a-time use (we share half a day the studio room)
I expected to have both computers connected (one with thunderbolt, and the other with USB) when I purchased the unit, and was hoping that the unit will detect the computer once it's on. This is not happening: The device detects one wire (USB or thunderbolt) and won't change to the other UNLESS YOU DISCONNECT IT FROM THE REAR OF THE UNIT.
I've checked with the MOTU help guys and it seems there's no way that I can switch from USB to Thunderbolt (or vice versa) except plugging/unplugging the device from this back. I can't do that since the unit it's inside a rack and it's not accessible.
It would be as simple as choosing USB or Thunderbolt from the menu if this option was available, but it isn't.
Does anybody have any idea of a workaround that may solve this situation?
Thanks very much in advance
Re: How to use the same interface (828es) with two computers?
Disconnect unused cable at computer?
Normally, the computer detects the interface. You have not posted enough info for me to guess why this isn't happening.was hoping that the unit will detect the computer once it's on
That is why.
If by "UNLESS YOU DISCONNECT IT FROM THE REAR OF THE UNIT" you mean, "Disconnect and re-connect," then never mind.
That is correct.
The MOTU unit is racked, and so is one of the computers (the main one). I cannot have access to the rear unless I move all the furniture.
The second computer is a laptop, and I was expecting that the unit would detect it when using it with the main computer switched off.
This next days I will try to put a quality USB KVM switch in between, but it's a idea that I don't really like.
Right now it is working with an active KVM usb switch (40€), and we even share a MIDI keyboard.
It's not a solution that I like, but at the moment it's making the trick with no problems.
Well congratulations for solving it. Perhaps it’s not optimum, but kudos to you for making it work. At the end of the day that’s what matters.nipper2 wrote:Right now it is working with an active KVM usb switch (40€), and we even share a MIDI keyboard.
For other people reading this, might you provide a link to the KVM switch in case somebody else wants to try this? Thanks!
I'm using this: https://www.anytrade.com.au/product/%E3 ... sb-switch/
I still want to see if it works without problem in the next days with different situations and more stress.
- Captura de pantalla 2024-04-03 a las 11.45.09.png (288.48 KiB) Viewed 178 times
Thanks for the info!
Anyways, I'd like to ask MOTU developers to implement a way where we can use both USB and Firewire without unracking the unit. I think it's fair considering the range of this device and the money we spent in it.
Maybe just choosing between them in the menu would be a simple option.
