DP 11.3 Crashes while running, but keeps running.
I'm working in DP11.3/Sonoma/MacStudioM1Ultra, Antelope Audio Zen Go, and get a crash message. When I click "OK" or "Reopen", DP just keeps running. Nothing quits or crashes, per se, but it seems to come at random.
Anybody get this?
I'm running Vienna Ensemble Pro 7.3 with lots of instruments. I suppose it could be that, and I'll check, but can anyone read the crash report? Sorry, but I'm going to paste it right here, edited down a bit, as I apparently can't attach a pdf or text:
Translated Report (Full Report Below)
Process: Digital Performer [2144]
Path: /Applications/Digital Performer.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 11.3 (11.3)
Code Type: ARM-64 (Native)
Parent Process: Digital Performer [1855]
Responsible: Digital Performer [1855]
User ID: 501
Date/Time: 2024-02-26 16:25:39.4532 -0800
OS Version: macOS 14.3.1 (23D60)
Report Version: 12
Anonymous UUID: 4ADA561A-5228-99D5-47E5-903BF20C6722
Time Awake Since Boot: 4900 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000015a00c438
Exception Codes: 0x0000000000000001, 0x000000015a00c438
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [2144]
VM Region Info: 0x15a00c438 is not in any region. Bytes after previous region: 17465 Bytes before following region: 15304
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
MALLOC_SMALL 15a000000-15a008000 [ 32K] rw-/rwx SM=COW
---> GAP OF 0x8000 BYTES
MALLOC_SMALL 15a010000-15a800000 [ 8128K] rw-/rwx SM=COW
Application Specific Information:
*** multi-threaded process forked ***
crashed on child side of fork pre-exec
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libMotuAlloc.dylib 0x102de4ec8 BuddySystemSubAllocator::Deallocate(void*) + 284
1 libMotuAlloc.dylib 0x102de7418 operator delete(void*) + 28
2 Network 0x18ed15b38 -[OS_nw_array dealloc] + 300
3 Network 0x18ecb8a00 -[NWConcrete_nw_protocol_stack .cxx_destruct] + 92
4 libobjc.A.dylib 0x18756f5f8 object_cxxDestructFromClass(objc_object*, objc_class*) + 116
5 libobjc.A.dylib 0x187566e7c objc_destructInstance + 80
6 libobjc.A.dylib 0x187566e24 _objc_rootDealloc + 80
7 Network 0x18ecb8a50 -[NWConcrete_nw_protocol_stack dealloc] + 44
8 Network 0x18efb4bd4 __nw_dictionary_dispose_block_invoke + 32
9 libxpc.dylib 0x18764f998 _xpc_dictionary_apply_apply + 68
10 libxpc.dylib 0x18764c130 _xpc_dictionary_apply_node_f + 156
11 libxpc.dylib 0x18764f878 xpc_dictionary_apply + 136
12 Network 0x18ed15efc -[OS_nw_dictionary dealloc] + 112
13 libobjc.A.dylib 0x18756f5f8 object_cxxDestructFromClass(objc_object*, objc_class*) + 116
14 libobjc.A.dylib 0x187566e7c objc_destructInstance + 80
15 libobjc.A.dylib 0x187566e24 _objc_rootDealloc + 80
16 Network 0x18ee95108 -[NWConcrete_nw_proxy_config dealloc] + 44
17 Network 0x18efb4bd4 __nw_dictionary_dispose_block_invoke + 32
18 libxpc.dylib 0x18764f998 _xpc_dictionary_apply_apply + 68
19 libxpc.dylib 0x18764c130 _xpc_dictionary_apply_node_f + 156
20 libxpc.dylib 0x18764f878 xpc_dictionary_apply + 136
21 Network 0x18ed15efc -[OS_nw_dictionary dealloc] + 112
22 Network 0x18f18bcb0 nw_path_release_globals + 164
23 Network 0x18f36dd8c nw_settings_child_has_forked() + 324
24 libsystem_pthread.dylib 0x187935f7c _pthread_atfork_child_handlers + 76
25 libsystem_c.dylib 0x1877e99c8 fork + 112
26 MAS VST3 Support 0x15e513dd8 MasVST3ValidationProcess::MasVST3ValidationProcess(__CFBundle*, VST_Class_Spec const&) + 248
27 MAS VST3 Support 0x15e52cfe4 MasVST3ValidationDlg::launchProcess(VST_Class_Spec const&, bool) + 56
28 MAS VST3 Support 0x15e52d530 ValidationProcessManager<MasVST3ValidationProcess, VST_Class_Spec>::tendProcessList() + 680
29 MAS VST3 Support 0x15e52d1e8 MasVST3ValidationDlg::IdleDuringDialog() + 68
30 MAS VST3 Support 0x15e544640 -[motu_MasVST3ValidationDlgImpl_ObjC run] + 80
31 MAS VST3 Support 0x15e516580 MasVST3InfoCache::getValidVSTs() + 504
32 MAS VST3 Support 0x15e545758 MotuPluginFactoryFunction + 288
33 MotuAudioSystem 0x1034b0cf4 MasWriteStandardAutomatableSurroundSetting + 39240
34 MotuAudioSystem 0x1034b0488 MasWriteStandardAutomatableSurroundSetting + 37084
35 MotuAudioSystem 0x1034adf30 MasWriteStandardAutomatableSurroundSetting + 27524
36 MotuAudioSystem 0x103453708 MAS83148 + 59612
37 MotuAudioSystem 0x10345db74 MAS83148 + 101704
38 MotuAudioSystem 0x103442b58 MAS82865 + 92
39 Digital Performer 0x1003a16ec StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>) + 2498676
40 PerfEngine.dylib 0x1054456f0 GlobalAudioDriver::Initialize(AudioDriverClassID const&, AudioDriverClient*, bool) + 376
41 Digital Performer 0x100145850 StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>) + 25048
42 Digital Performer 0x100f6db50 StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>) + 14869720
43 libMotuCoreLibs.dylib 0x1031d5a6c CIdleChore::IdleAndReturnNextIdleTime() + 600
44 OSFoundation.dylib 0x102f615ec IdleOnExit::~IdleOnExit() + 32
45 OSFoundation.dylib 0x102f752a8 GlogEventFilter::HandleUIEvent(UIEvent&) + 96
46 OSFoundation.dylib 0x102fbb864 OS::EventImpl::DispatchToApplication(UIEvent, boost::optional<MotuOSWindow::OSWindow&>) + 344
47 OSFoundation.dylib 0x102f7fdb8 RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>) + 10924
48 OSFoundation.dylib 0x102f812ec RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>) + 16352
49 AppKit 0x18bd1e27c _routeMouseMovedEvent + 288
50 AppKit 0x18b318430 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 432
51 AppKit 0x18b3180ac -[NSWindow(NSEventRouting) sendEvent:] + 284
52 OSFoundation.dylib 0x102fc2e98 OS::WindowManager::GetActiveWindow() + 6820
53 AppKit 0x18b9d74f8 routeMouseMovedEvent + 120
54 AppKit 0x18b9d6d98 -[NSApplication(NSEventRouting) sendEvent:] + 1148
55 OSFoundation.dylib 0x102f7dfa4 RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>) + 3224
56 AppKit 0x18b6275bc -[NSApplication _handleEvent:] + 60
57 AppKit 0x18b1e03a0 -[NSApplication run] + 512
58 AppKit 0x18b1b7640 NSApplicationMain + 880
59 OSFoundation.dylib 0x102f7d508 RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>) + 508
60 Digital Performer 0x100e6cdf4 StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>) + 13817724
61 dyld 0x1875b10e0 start + 2360
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x000000015a00bbf0 x2: 0x0000000000004000 x3: 0x00000000000b032b
x4: 0x0000000000000000 x5: 0x00000000000b032c x6: 0x000000015a00bc00 x7: 0x00000000000b032b
x8: 0x0000000010000003 x9: 0xffffffffffffc000 x10: 0x00000004e7ac56e0 x11: 0x000000010dbeb114
x12: 0x0000000000010db8 x13: 0x00000004e7ac56ea x14: 0x000000010dbeb110 x15: 0x0000000000010dbe
x16: 0xfffffffffffffff4 x17: 0x00000001dfbebcc0 x18: 0x0000000000000000 x19: 0x000000015a00bc00
x20: 0x000000015a00bc30 x21: 0x00000000facef00d x22: 0x000000014ff239a0 x23: 0x00000001de203000
x24: 0x00000001dd070000 x25: 0x0000000000000000 x26: 0x0000000000000051 x27: 0x000000010c389060
x28: 0x000000010dc4a600 fp: 0x000000016fd35240 lr: 0x9774800102de4ec8
sp: 0x000000016fd35220 pc: 0x0000000102de4ec8 cpsr: 0x80001000
far: 0x000000015a00c438 esr: 0x92000007 (Data Abort) byte read Translation fault
<SNIP>
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2.3G resident=0K(0%) swapped_out_or_unallocated=2.3G(100%)
Writable regions: Total=16.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=16.6G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
CG image 1536K 85
ColorSync 688K 33
CoreAnimation 2912K 121
CoreGraphics 48K 3
CoreImage 16K 1
CoreServices 624K 2
CoreUI image data 1984K 28
Foundation 48K 2
Image IO 176K 11
JS JIT generated code 512.0M 3
Kernel Alloc Once 32K 1
MALLOC 8.2G 1140
MALLOC guard page 576K 36
MALLOC_LARGE (reserved) 9248K 1 reserved VM address space (unallocated)
SQLite page cache 384K 3
STACK GUARD 56.0M 1
Stack 73.5M 225
Stack Guard 1904K 119
VM_ALLOCATE 3.7G 30070
VM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)
WebKit Malloc 256.1M 5
WebKit Malloc (reserved) 32.0M 1 reserved VM address space (unallocated)
__AUTH 2164K 396
__AUTH_CONST 31.2M 613
__CTF 824 1
__DATA 83.7M 859
__DATA_CONST 53.5M 780
__DATA_DIRTY 1953K 220
__FONT_DATA 4K 1
__GLSLBUILTINS 5174K 1
__INFO_FILTER 8 1
__LINKEDIT 964.8M 167
__MFRT 48K 3
__OBJC_RO 71.2M 1
__OBJC_RW 2171K 1
__POVERDDATA 32K 2
__POVERTEXT 32K 2
__TEXT 1.4G 805
dyld private memory 272K 2
libnetwork 640K 16
mapped file 609.6M 267
shared memory 784K 44
TOTAL 19.8G 36075
TOTAL, minus reserved VM space 15.9G 36075
Full Report
{"app_name":"Digital Performer","timestamp":"2024-02-26 16:25:40.00 -0800","app_version":"11.3","slice_uuid":"347fba97-1f16-39d7-9e41-a17f3d29a437","build_version":"11.3","platform":1,"bundleID":"com.motu.DigitalPerformer","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.3.1 (23D60)","roots_installed":0,"name":"Digital Performer","incident_id":"99D8927B-C3CE-45B2-A296-6176C867923D"}
"uptime" : 4900,
"procRole" : "Unspecified",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac13,2",
"coalitionID" : 1332,
"osVersion" : {
"train" : "macOS 14.3.1",
"build" : "23D60",
"releaseType" : "User"
"captureTime" : "2024-02-26 16:25:39.4532 -0800",
"codeSigningMonitor" : 1,
"incident" : "99D8927B-C3CE-45B2-A296-6176C867923D",
"pid" : 2144,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2024-02-26 16:25:39.0666 -0800",
"procStartAbsTime" : 119026229647,
"procExitAbsTime" : 119035499300,
"procName" : "Digital Performer",
"procPath" : "\/Applications\/Digital Performer.app\/Contents\/MacOS\/Digital Performer",
"bundleInfo" : {"CFBundleShortVersionString":"11.3","CFBundleVersion":"11.3","CFBundleIdentifier":"com.motu.DigitalPerformer"},
"storeInfo" : {"deviceIdentifierForVendor":"D9229915-2B29-5FF1-8BEF-E8EE3AAB6D54","thirdParty":true},
"parentProc" : "Digital Performer",
"parentPid" : 1855,
"coalitionName" : "com.motu.DigitalPerformer",
"crashReporterKey" : "4ADA561A-5228-99D5-47E5-903BF20C6722",
"responsiblePid" : 1855,
"responsibleProc" : "Digital Performer",
"codeSigningID" : "com.motu.DigitalPerformer",
"codeSigningTeamID" : "KRCLLMGZ2D",
"codeSigningFlags" : 570491393,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"instructionByteStream" : {"beforePC":"YBZA+QEAgNKZCQCUQAMAtLUBnlLVWb9ydMIAkQoAABTIBQCUyQUAlA==","atPC":"aDpIuQgFAFFoOgi5YBZA+QEAgNKMCQCUoAEAtAgIQLkfARVrof7\/VA=="},
"sip" : "enabled",
"vmRegionInfo" : "0x15a00c438 is not in any region. Bytes after previous region: 17465 Bytes before following region: 15304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n MALLOC_SMALL 15a000000-15a008000 [ 32K] rw-\/rwx SM=COW \n---> GAP OF 0x8000 BYTES\n MALLOC_SMALL 15a010000-15a800000 [ 8128K] rw-\/rwx SM=COW ",
"exception" : {"codes":"0x0000000000000001, 0x000000015a00c438","rawCodes":[1,5804966968],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x000000015a00c438"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2144},
"vmregioninfo" : "0x15a00c438 is not in any region. Bytes after previous region: 17465 Bytes before following region: 15304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n MALLOC_SMALL 15a000000-15a008000 [ 32K] rw-\/rwx SM=COW \n---> GAP OF 0x8000 BYTES\n MALLOC_SMALL 15a010000-15a800000 [ 8128K] rw-\/rwx SM=COW ",
"asi" : {"CoreFoundation":["*** multi-threaded process forked ***"],"libsystem_c.dylib":["crashed on child side of fork pre-exec"]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":64743,"threadState":{"x":[{"value":0},{"value":5804964848},{"value":16384},{"value":721707},{"value":0},{"value":721708},{"value":5804964864},{"value":721707},{"value":268435459},{"value":18446744073709535232},{"value":21066700512},{"value":4525568276},{"value":69048},{"value":21066700522},{"value":4525568272},{"value":69054},{"value":18446744073709551604},{"value":8048786624},{"value":0},{"value":5804964864},{"value":5804964912},{"value":4207865869},{"value":5636241824},{"value":8021618688,"symbolLocation":672,"symbol":"objc_debug_taggedpointer_ext_classes"},{"value":8003190784,"symbolLocation":0,"symbol":"OBJC_IVAR_$_Object.isa"},{"value":0},{"value":81},{"value":4500000864},{"value":4525958656}],"flavor":"ARM_THREAD_STATE64","lr":{"value":10913488538857000648},"cpsr":{"value":2147487744},"fp":{"value":6171087424},"sp":{"value":6171087392},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4343090888,"matchesCrashFrame":1},"far":{"value":5804966968}},"queue":"com.apple.main-thread","frames":[{"imageOffset":20168,"symbol":"BuddySystemSubAllocator::Deallocate(void*)","symbolLocation":284,"imageIndex":152},{"imageOffset":29720,"symbol":"operator delete(void*)","symbolLocation":28,"imageIndex":152},{"imageOffset":3275576,"symbol":"-[OS_nw_array dealloc]","symbolLocation":300,"imageIndex":166},{"imageOffset":2894336,"symbol":"-[NWConcrete_nw_protocol_stack .cxx_destruct]","symbolLocation":92,"imageIndex":166},{"imageOffset":79352,"symbol":"object_cxxDestructFromClass(objc_object*, objc_class*)","symbolLocation":116,"imageIndex":167},{"imageOffset":44668,"symbol":"objc_destructInstance","symbolLocation":80,"imageIndex":167},{"imageOffset":44580,"symbol":"_objc_rootDealloc","symbolLocation":80,"imageIndex":167},{"imageOffset":2894416,"symbol":"-[NWConcrete_nw_protocol_stack dealloc]","symbolLocation":44,"imageIndex":166},{"imageOffset":6024148,"symbol":"__nw_dictionary_dispose_block_invoke","symbolLocation":32,"imageIndex":166},{"imageOffset":43416,"symbol":"_xpc_dictionary_apply_apply","symbolLocation":68,"imageIndex":168},{"imageOffset":28976,"symbol":"_xpc_dictionary_apply_node_f","symbolLocation":156,"imageIndex":168},{"imageOffset":43128,"symbol":"xpc_dictionary_apply","symbolLocation":136,"imageIndex":168},{"imageOffset":3276540,"symbol":"-[OS_nw_dictionary dealloc]","symbolLocation":112,"imageIndex":166},{"imageOffset":79352,"symbol":"object_cxxDestructFromClass(objc_object*, objc_class*)","symbolLocation":116,"imageIndex":167},{"imageOffset":44668,"symbol":"objc_destructInstance","symbolLocation":80,"imageIndex":167},{"imageOffset":44580,"symbol":"_objc_rootDealloc","symbolLocation":80,"imageIndex":167},{"imageOffset":4845832,"symbol":"-[NWConcrete_nw_proxy_config dealloc]","symbolLocation":44,"imageIndex":166},{"imageOffset":6024148,"symbol":"__nw_dictionary_dispose_block_invoke","symbolLocation":32,"imageIndex":166},{"imageOffset":43416,"symbol":"_xpc_dictionary_apply_apply","symbolLocation":68,"imageIndex":168},{"imageOffset":28976,"symbol":"_xpc_dictionary_apply_node_f","symbolLocation":156,"imageIndex":168},{"imageOffset":43128,"symbol":"xpc_dictionary_apply","symbolLocation":136,"imageIndex":168},{"imageOffset":3276540,"symbol":"-[OS_nw_dictionary dealloc]","symbolLocation":112,"imageIndex":166},{"imageOffset":7953584,"symbol":"nw_path_release_globals","symbolLocation":164,"imageIndex":166},{"imageOffset":9928076,"symbol":"nw_settings_child_has_forked()","symbolLocation":324,"imageIndex":166},{"imageOffset":44924,"symbol":"_pthread_atfork_child_handlers","symbolLocation":76,"imageIndex":169},{"imageOffset":141768,"symbol":"fork","symbolLocation":112,"imageIndex":170},{"imageOffset":15832,"symbol":"MasVST3ValidationProcess::MasVST3ValidationProcess(__CFBundle*, VST_Class_Spec const&)","symbolLocation":248,"imageIndex":122},{"imageOffset":118756,"symbol":"MasVST3ValidationDlg::launchProcess(VST_Class_Spec const&, bool)","symbolLocation":56,"imageIndex":122},{"imageOffset":120112,"symbol":"ValidationProcessManager<MasVST3ValidationProcess, VST_Class_Spec>::tendProcessList()","symbolLocation":680,"imageIndex":122},{"imageOffset":119272,"symbol":"MasVST3ValidationDlg::IdleDuringDialog()","symbolLocation":68,"imageIndex":122},{"imageOffset":214592,"symbol":"-[motu_MasVST3ValidationDlgImpl_ObjC run]","symbolLocation":80,"imageIndex":122},{"imageOffset":25984,"symbol":"MasVST3InfoCache::getValidVSTs()","symbolLocation":504,"imageIndex":122},{"imageOffset":218968,"symbol":"MotuPluginFactoryFunction","symbolLocation":288,"imageIndex":122},{"imageOffset":543988,"symbol":"MasWriteStandardAutomatableSurroundSetting","symbolLocation":39240,"imageIndex":163},{"imageOffset":541832,"symbol":"MasWriteStandardAutomatableSurroundSetting","symbolLocation":37084,"imageIndex":163},{"imageOffset":532272,"symbol":"MasWriteStandardAutomatableSurroundSetting","symbolLocation":27524,"imageIndex":163},{"imageOffset":161544,"symbol":"MAS83148","symbolLocation":59612,"imageIndex":163},{"imageOffset":203636,"symbol":"MAS83148","symbolLocation":101704,"imageIndex":163},{"imageOffset":93016,"symbol":"MAS82865","symbolLocation":92,"imageIndex":163},{"imageOffset":2987756,"symbol":"StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>)","symbolLocation":2498676,"imageIndex":165},{"imageOffset":7870192,"symbol":"GlobalAudioDriver::Initialize(AudioDriverClassID const&, AudioDriverClient*, bool)","symbolLocation":376,"imageIndex":158},{"imageOffset":514128,"symbol":"StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>)","symbolLocation":25048,"imageIndex":165},{"imageOffset":15358800,"symbol":"StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>)","symbolLocation":14869720,"imageIndex":165},{"imageOffset":809580,"symbol":"CIdleChore::IdleAndReturnNextIdleTime()","symbolLocation":600,"imageIndex":154},{"imageOffset":153068,"symbol":"IdleOnExit::~IdleOnExit()","symbolLocation":32,"imageIndex":157},{"imageOffset":234152,"symbol":"GlogEventFilter::HandleUIEvent(UIEvent&)","symbolLocation":96,"imageIndex":157},{"imageOffset":522340,"symbol":"OS::EventImpl::DispatchToApplication(UIEvent, boost::optional<MotuOSWindow::OSWindow&>)","symbolLocation":344,"imageIndex":157},{"imageOffset":277944,"symbol":"RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>)","symbolLocation":10924,"imageIndex":157},{"imageOffset":283372,"symbol":"RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>)","symbolLocation":16352,"imageIndex":157},{"imageOffset":11973244,"symbol":"_routeMouseMovedEvent","symbolLocation":288,"imageIndex":171},{"imageOffset":1463344,"symbol":"-[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:]","symbolLocation":432,"imageIndex":171},{"imageOffset":1462444,"symbol":"-[NSWindow(NSEventRouting) sendEvent:]","symbolLocation":284,"imageIndex":171},{"imageOffset":552600,"symbol":"OS::WindowManager::GetActiveWindow()","symbolLocation":6820,"imageIndex":157},{"imageOffset":8537336,"symbol":"routeMouseMovedEvent","symbolLocation":120,"imageIndex":171},{"imageOffset":8535448,"symbol":"-[NSApplication(NSEventRouting) sendEvent:]","symbolLocation":1148,"imageIndex":171},{"imageOffset":270244,"symbol":"RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>)","symbolLocation":3224,"imageIndex":157},{"imageOffset":4670908,"symbol":"-[NSApplication _handleEvent:]","symbolLocation":60,"imageIndex":171},{"imageOffset":185248,"symbol":"-[NSApplication run]","symbolLocation":512,"imageIndex":171},{"imageOffset":17984,"symbol":"NSApplicationMain","symbolLocation":880,"imageIndex":171},{"imageOffset":267528,"symbol":"RunApplicationWithDelegate(int, char**, std::__1::unique_ptr<MOTUApplicationDelegate, std::__1::default_delete<MOTUApplicationDelegate>>)","symbolLocation":508,"imageIndex":157},{"imageOffset":14306804,"symbol":"StateMachine<Timebase::ClockMode>::StateMachine(std::__1::shared_ptr<Timebase::ClockMode>)","symbolLocation":13817724,"imageIndex":165},{"imageOffset":24800,"symbol":"start","symbolLocation":2360,"imageIndex":172}]}],
"usedImages" : [
<SNIP>
"vmSummary" : "ReadOnly portion of Libraries: Total=2.3G resident=0K(0%) swapped_out_or_unallocated=2.3G(100%)\nWritable regions: Total=16.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=16.6G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nCG image 1536K 85 \nColorSync 688K 33 \nCoreAnimation 2912K 121 \nCoreGraphics 48K 3 \nCoreImage 16K 1 \nCoreServices 624K 2 \nCoreUI image data 1984K 28 \nFoundation 48K 2 \nImage IO 176K 11 \nJS JIT generated code 512.0M 3 \nKernel Alloc Once 32K 1 \nMALLOC 8.2G 1140 \nMALLOC guard page 576K 36 \nMALLOC_LARGE (reserved) 9248K 1 reserved VM address space (unallocated)\nSQLite page cache 384K 3 \nSTACK GUARD 56.0M 1 \nStack 73.5M 225 \nStack Guard 1904K 119 \nVM_ALLOCATE 3.7G 30070 \nVM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)\nWebKit Malloc 256.1M 5 \nWebKit Malloc (reserved) 32.0M 1 reserved VM address space (unallocated)\n__AUTH 2164K 396 \n__AUTH_CONST 31.2M 613 \n__CTF 824 1 \n__DATA 83.7M 859 \n__DATA_CONST 53.5M 780 \n__DATA_DIRTY 1953K 220 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 964.8M 167 \n__MFRT 48K 3 \n__OBJC_RO 71.2M 1 \n__OBJC_RW 2171K 1 \n__POVERDDATA 32K 2 \n__POVERTEXT 32K 2 \n__TEXT 1.4G 805 \ndyld private memory 272K 2 \nlibnetwork 640K 16 \nmapped file 609.6M 267 \nshared memory 784K 44 \n=========== ======= ======= \nTOTAL 19.8G 36075 \nTOTAL, minus reserved VM space 15.9G 36075 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"logWritingSignature" : "db7e2c7aa8893a6cf9bbb5d2fd6e1e7c174789bd",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "632e3f9c01482c74ed76392d",
"factorPackIds" : {
"SIRI_TEXT_TO_SPEECH" : "65c56d96ac449c5a91b3181b"
"deploymentId" : 240000405
"rolloutId" : "62745b8e85854550ad70b6e4",
"factorPackIds" : {
"SIRI_TTS_DEVICE_TRAINING" : "6539d7f333b9b7499c6f1b63"
"deploymentId" : 240000073
"experiments" : [
Model: Mac13,2, BootROM 10151.81.1, proc 20:16:4 processors, 128 GB, SMC
Graphics: Apple M1 Ultra, Apple M1 Ultra, Built-In
Display: Acer B273HU, 2048 x 1152, Main, MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Sep 1 2023 19:46:54 version 20.10.1073.3.8.7.165 FWID 01-4780e8c5
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
<Snip list of peripherals>
Anybody get this?
User ID: 501
Report Version: 12
<SNIP>
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
VIRTUAL REGION
CG image 1536K 85
ColorSync 688K 33
CoreGraphics 48K 3
CoreImage 16K 1
CoreServices 624K 2
Foundation 48K 2
Image IO 176K 11
MALLOC 8.2G 1140
STACK GUARD 56.0M 1
Stack 73.5M 225
__AUTH 2164K 396
__CTF 824 1
__DATA 83.7M 859
__FONT_DATA 4K 1
__INFO_FILTER 8 1
__MFRT 48K 3
__OBJC_RO 71.2M 1
__OBJC_RW 2171K 1
__POVERDDATA 32K 2
__POVERTEXT 32K 2
__TEXT 1.4G 805
libnetwork 640K 16
TOTAL 19.8G 36075
Full Report
"uptime" : 4900,
"version" : 2,
"userID" : 501,
"osVersion" : {
"build" : "23D60",
"pid" : 2144,
"bug_type" : "309",
"parentPid" : 1855,
"sip" : "enabled",
"usedImages" : [
<SNIP>
"legacyInfo" : {
"trialInfo" : {
"rollouts" : [
"factorPackIds" : {
"factorPackIds" : {
"experiments" : [
AirPort:
Mac Studio M1 128gb, DP. LPX, OWC Thunderbay external 4 bay SSD, Antelope Audio Zen Go, Presonus Monitor Station V2, Event 2020 powered monitors (1st gen). Best thing = CyberPower UPS!!! We have wind, rain, snow, ice, and lots of power outages!
Re: DP 11.3 Crashes while running, but keeps running.
So I get this too, it's a weird one. You're crash report, the first thing to notice is it states which thread crashed, thread 0, then the second thing is it looks like you snipped most of the report on thread 0? So what you want to do to maybe get a clue on why a crash occurs is to look for that first statement in your case right at the beginning, "Crashed Thread: 0 Dispatch queue: com.apple.main-thread", then look at the paragraphs separated out usually on that thread. I tend to look for plugins.
Yup. I have seen that too. No ideas. Bizzaro!
Michael -
I KNEW I'd screw up what to include and what not to include. I'm sorta lousy when it comes to code.
I just had a very good experience with Motu tech support on another issue. I'll ask them about this and then post their answer.
I also get this on a regular basis. I haven't been able to determine an action, plug in, or scenario that makes it more likely to occur.
DP 11.31 is released today with many bug fixes that involve crashing. I’d run that update first.
