I have a 828x.
On my laptop it works fine, on my desktop the USB device is not recognized. "configuration descriptor request failed" error.
Both are Windows 10.
I tried to remove and re-install the driver.
Tried to reboot.
I did all the relevant tweaks listed here: https://motu.com/techsupport/technotes/ ... dows-audio
Nothing. Still the same error.
Please advise, I really need to get this device working on my desktop.
828x USB error "configuration descriptor request failed" - but works on another computer
- Primary DAW OS: Windows
Re: 828x USB error "configuration descriptor request failed" - but works on another computer
Try connecting through a USB 2 hub. My motherboard's USB 3 controller got confused by the 828x USB 2 device.
If that works, order up a USB Printer cable from Amazon and connect directly. These support USB 2/1.1 only. Yamaha is now recommending these for their keyboards with connection issues.
USB 3 and USB 2 are separate protocols using different wires in the cable with a common ground and not all cables support both.
DP 11.33; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.7.1/Sequoia 15.1, USB4 8TB externals, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
