Anyone try headphone for adat mk5
Hello, has anyone tried to use the ultralite mk5 as a dac via adat? Does anyone know if the headphone jack shows up in as an output? Like 7-8 etc? Want to get one but I would primarily use it this way if I did.
Here is the User Guide.
https://cdn-data.motu.com/manuals/usb- ... _Guide.pdf
It can do what you want but not the way you think you want it. ADAT is one of multiple input sources.
Headphone output
The UltraLite-mk5 front panel provides an independent headphone jack with separate volume control. You can program the phones to mirror the main outs or act as its own independent output.
Re: Anyone try headphone for adat mk5
Interesting, I looked in the manual but must have been looking in the wrong section. Thanks for the reply I guess that’s probably as informative an answer as I could expect to get without actually having one and trying it.
I'm answering very late to your question, and I'm not sure if I understood your question, but the headphones output is a separate output indeed : you can use it as a replica of the master, or you can route to it the USB channels 11-12 from your DAW...
If I'm not wrong, SPDIF is 13-14
ADAT is 15-16-17-18-19-20-21-22
It's actually very useful if you need to use more than 10 outputs and don't care about the quality of the 11-12 outputs
(in my case, I use it on stage and the headphones output is used as a click track, so the whole 10 tracks are used for music).
