resonance suppressor?
harmonicaman
Post by harmonicaman »
Please let me know how I can get rid of Harmoncia Resonance
What plugin should I use ?
Thanks in advance
Re: resonance suppressor?
harmonicaman wrote: Fri Feb 11, 2022 11:17 pm Please let me know how I can get rid of Harmoncia Resonance
Not sure what you mean by harmonica resonance? Sounds like you need an Equalizer.
harmonicaman
James Steele wrote: Sat Feb 12, 2022 3:40 am
Yes I was trying to use EQ to resolve this but not much success . Let me explain
I play harmonica with guitar and as I use the harp in harmonica rack I can not hold it inside my hand therefore the sound is not round and it is thin
listen to this
I need to change this sound
https://soundcloud.com/user-962007871/h ... al_sharing
to this sound
Wonder if there is a plugin except eq that can make the life easier for me :)
Thanks in advance
dix
Post by dix »
I'm not sure I'd call that resonance - you just want to get that buzzyness out I guess? It's an EQ solution, but if a steep lowpass filter doesn't work, my first move'd be FabFilter Pro-Q and see if you can see the offending frequency and remove it. Any EQ that displays frequency would could do it, but Pro-Q lets you easily, and precisely isolate and grab just the buzzy frequency and pull it down.
harmonicaman
dix wrote: Sat Feb 12, 2022 12:27 pm I'm not sure I'd call that resonance - you just want to get that buzzyness out I guess? It's an EQ solution, but if a steep lowpass filter doesn't work, my first move'd be FabFilter Pro-Q and see if you can see the offending frequency and remove it. Any EQ that displays frequency would could do it, but Pro-Q lets you easily, and precisely isolate and grab just the buzzy frequency and pull it down.
Thanks I think I can get some results from EQ alone but that plugin is too expensive for me right now
Thanks in advance
dix
Post by dix »
DP's Masterworks EQ should suffice I'd think. Make sure the FFT Frequency Analysis is ON. You should be able to see the buzzy frequency to notch out.
