Two tin cans and a long string?labman wrote:So whats the best way to get from MacPro in machine room out 35 feet to Raven? (Please forgive if someone somewhere already answered this.)
The Raven MTi2 Thread
- toodamnhip
Re: The Raven MTi2 Thread
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
LOL!toodamnhip wrote:Two tin cans and a long string?
What size can? What gauge string?
- toodamnhip
Thats classified info only available if you buy the Slate “everything" Bundle.labman wrote:LOL!toodamnhip wrote:Two tin cans and a long string?
You see, “everything” means EVERYTHING...
In case you don't know, tin cans and strings are a part of “everything” there is, and Slate sells it.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Jeepers. I do own two of the 'everything' licenses. I guess they left the strings and can out of my box.toodamnhip wrote:Thats classified info only available if you buy the Slate “everything" Bundle.labman wrote:LOL!toodamnhip wrote:Two tin cans and a long string?
if you are talking about a macpro trash can use the hdmi out to a SDI converter and amp the signal. HDMI is 25 feet at best but HDMI cables are expensive... Use a usb extender cable with a signal amp... both cables solutions are about $50labman wrote:So whats the best way to get from MacPro in machine room out 35 feet to Raven? (Please forgive if someone somewhere already answered this.)
waxman
I have an older tower Mac Pro, but my third party video card has both a DVI and an HDMI out on it. (Currently only using DVI). I have a bunch of USB amps thank aren't being used. But have never heard of SDI converter. What brand do you use Waxman?waxman wrote: if you are talking about a macpro trash can use the hdmi out to a SDI converter and amp the signal. HDMI is 25 feet at best but HDMI cables are expensive... Use a usb extender cable with a signal amp... both cables solutions are about $50
Thanks for your help! I am sorta excited to see how the raven helps my workflow.
So far everything is working. Screen isn't reacting as smooth as I would like. Probably need to re-vitalize.
On the V-Control Pro thing, it is obviously working. Do we still need to purchase it from Neyrinck? Or is that included with the Slate purchase.
Need some help Waxman and TooDamn and all you Raven veterans. Are your DP track names in TO window and Markers window sharp. Mine aint. They are jagged and a bit smeary.
- toodamnhip
They are sharplabman wrote:Need some help Waxman and TooDamn and all you Raven veterans. Are your DP track names in TO window and Markers window sharp. Mine aint. They are jagged and a bit smeary.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Hmmm... Can you read PDFs just as easily as on your mac screen? Are you coming off Mac directly or thru HDMI amplifier?toodamnhip wrote:They are sharplabman wrote:Need some help Waxman and TooDamn and all you Raven veterans. Are your DP track names in TO window and Markers window sharp. Mine aint. They are jagged and a bit smeary.
I'm confused... In the DP window on a second monitor or the Raven?
waxman
On the Raven screen. Reading a PDF is pretty hard on eyes. And the DP track names and marker window text is jagged too. Is it because the pixel size is larger, or because we are sitting right on top of it? Or is your text all peachy nice?waxman wrote:I'm confused... In the DP window on a second monitor or the Raven?
(All is just fine with text on the other monitors)
my text is sharp... do you have display set to Raven default? Check with JameyZ on Slate forum.
waxman
Jamey and I have been working on it. Hoping for solution soon. MY elderly eyes can't handle it.
Need some help with Raven mixer.
How do I show only certain tracks in the Raven mixer. In DP we have mixer layouts and now in DP 9 we have track Layouts too, which show or hide desired trks. I have 450+ trks in my orch template and am always switching to see only the strgs, or precussion etc. How do I make the Raven mixer mirror what is seen in DP?
