Hi. I just upgraded to DP9 with MX4 and have a newbie question.
Whenever I hit play in DP, my MX4 reverts back to Bank 1, Patch 1, even if I have no CCs or other events (other than notes) in my track whatsoever.
I can't find a place to have it stop doing this. Help!
I meant "program" not "progrem."
Thank you,
Jim
unwanted progrem changes
Re: unwanted progrem changes
The only other place I can think of to look is in the TO (tracks overview) in the columns "Patch" and "Default Patch".
That is a good guess, but that wasn't it. Thanks for taking the time to reply! I appreciate it.
I've edited my earlier reply:
I thought I'd worked around it by creating a new track and pasting the "old" events into it.
But, I started working on another older Project started in an earlier version of DP, and put MX4 on a track, hit play, and MX4 changed patches on its own while playing several times. And again, this is without any Program Change events in the Track.
Jim
Jim
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
- daniel.sneed
Just guessing. For troubleshooting, my 1st test would be disabling program change in view filter window.
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
Falcon, Kontakt, Ozone, RX, Unisum & Michelangelo, LX480, Sparkverb
You can go to the initial post (if it’s yours) and select EDIT. Then correct/change the title.Jim wrote:
Thank you,
Jim
