I am using the 64 bit MSI with UVI Workstation in DP8, and have 2 issues!
1. The volume and pan settings in the UVI window don't follow the faders in DP.
Should they? Is there a setting I have wrong?
2. Any currently sounding note is cut off by adjusting anything in the DP mix window.
Can this be stopped?
Thank you, in advance, pool of wisdom!
UVI Workstation cuts out when mixing
- Martin Tenbones
iMac, 2.9 GHz Intel Core i5, 8 GB RAM, 10.11.2, 828 mk3 Hybrid, DP8.01, Symphonic Instrument, Roland JV 1010, original 828, Boss RV70, Golden Age Pre-73 dlx
