i have updateted to the newest version 1.5.1 but bpm crashes every time!
when i would make slices in the sampler it crasches,when i make some twea¨king of the parameters it crashes,and freez!
is this and error from fault setings or a bug?
Moderator: ssp
Re: bpm crashes every time!
Hi,
What version of windows are you using? - I'm interested in this as I've got some of the UVI-soundcards which will be good with this groovebox...
I saw this over the weekend but I did not have an opportunity to respond.
This happend to me as well and I was almost done with BPM because I had just installed the 1.5.1 update and I thought the update broke BPM. The problem was not BPM. My problem was that I was trying to chop .mp3 and .m4a files. All hell broke loose in my app just the way you described. Until I realized my error. .aif and .wav files worked just fine. Make sure you are working with a sliceable format.
Not sure if that is your issue but I had a similar experience doing the above.
