Some Issues I've seen so far with BPM using x64 Vista
Moderator: ssp
Cairns
Post by Cairns »
Hey everyone,
I have seen some issues so far with BPM and Vista x64, don't worry you will be up an running in no time..
#1. You might be experiencing some problems with your iLok, yes I did too and MOTU is aware of the situation (they are fixing it as I type this).
#2.. For x64 Vista users when it comes time to install the DVDs of Sounds, you might be stumped when the manual and the Readme file both say "startup disk:\Program Files\MOTU\BPM\Plug-in\Sounds" ---Vista doesn't create this file.. so all you have to do is go to your program files (mine is in the C drive hence the startup disk name) click on MOTU then select BPM then create a file and name it sounds or plug-in then you can copy or drag your sounds from the DVD over..
Stay tuned..
Music is a moral law,
it gives wings to the mind,
a soul to the universe,
flight to the imagination,
a charm to sadness,
a life to everything,
Plato 400 B.C.
superjeezus
Re: Some Issues I've seen so far with BPM using x64 Vista
Post by superjeezus »
I had the iLok issue as well. MOTU was great and resolved the issue very quickly.
So if you are launching BPM for the first time, and your iLok is inserted (and you installed the iLok drivers), and you get errors that the BPM ilok license isn't found, go to ilok.com and take a look at that iLok. Call MOTU and they will set it straight.
I hope for their sake the problem is limited and isn't with every copy that has shipped so far! :shock:
Late 2008 MacPro 2.8 8-core, 2408mkIII, 10.6.2, Lots of RAM and HD, DP7.1
Cairns
Post by Cairns »
Amen to that...
Anyways Motu tech support is excellent, unforunately Motu and myself couldn't solve this issue.. Until I contacted my sales rep.. which he is the shizz (you know what), he overnighted me a tested and new iLok.. Okay so tomorrow we will see..
a charm to sadness,
Plato 400 B.C.
Please post in the BPM (Windows) forum... thanks! :D
Cairns
Post by Cairns »
Sorry homie,
Here is the final update.. I got overnighted the new iLok (at 8:00 this morning by UPS banging on the door). Popped it in and I've neglected my family for about 2 hours now..Works like a charm.. for those using Cakewalk Sonar 8 please copy the BPM.dll and BPMSampler.dll into your cakewalk vst folder, I'm loving this thing...
Another side note: I've notice that Sonar 8 is "thinking about sharing CPU with BPM as a plugin" I've noticed some serious spikes when I load BPM as a plug in, BPM wants to take all the cpu, I've adjusted my buffers to 1024 on my Ultralite mk3 an it works fine, but I will need to play around to get it alittle lower.
ALSO... FOR ALL YOU ROLAND MV Users out there.. so far I can control the BPM pads and transport using the MV8000 (this goes for the MV8800 also) I'm currently working on some more controls as soon as I get full control of the BPM features..
a charm to sadness,
Plato 400 B.C.
rahquee
Post by rahquee »
I can control the BPM transport
how?
please explain.....
hugy
Post by hugy »
BPM uses standard MIDI CC to control its transport bar.
CC 117 is stop
CC 118 is play
CC 119 is record
Hope this helps.
rahquee
Post by rahquee »
cool any other controls syncd besides transport and obviouse "learn" pads?
thank you
rahquee
Post by rahquee »
not helpin me wit the mpd 32 but great for my mv8k!
hugy
Post by hugy »
Some on the rack
CC #7 for rack volume (editing)
CC #10 for rack pan (editing)
CC #11 for rack volume expression(modulation)
HTH
hugy
Post by hugy »
rahquee wrote:not helpin me wit the mpd 32 but great for my mv8k!
I would advise you to create a BPM template on the MPD32 with the following MIDI key
45 75 56 70
41 49 51 46
37 39 42 44
36 35 38 40
HTH
rahquee
Post by rahquee »
very helpfull...thanks!
yoonchul
Post by yoonchul »
sorry, wrong topic - feel free to delete the post since I have no idea how to
